Old 07-04-2023   #1
Liam95ZR1
Default 1995 ZR1 Power Steering Cooler
Any recommendations where to find a replacement Power Steering Fluid Cooler? I think it's part #26033592. The PO banged mine up pretty bad and does not look repairable. Thanks for any suggestions.
Liam95ZR1 is offline   Reply With Quote
Old 07-14-2023   #2
Liam95ZR1
Default Re: 1995 ZR1 Power Steering Cooler
Nobody can help with this?
Old 07-14-2023   #3
HAWAIIZR-1's Avatar
Did you already try Mark at Mirrock Corvette?
https://mirrockcorvette.com/
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 07-14-2023   #4
If you cannot find a correct one for ZR-1, a cooler for L98 Corvette can be made to work with careful bending of upper pipe. L98 had power steering pump on the driver side like our LT5.
LT1 (92 to 96) has power steering pump on the passenger side.
I replaced mine with cooler out of 91 L98 Corvette.
Old 07-22-2023   #5
Liam95ZR1
Thx! Will look into that.
