Old 08-06-2022   #31
albeR/To
Thumbs up Re: Rebuilding The LT5 Tensioner
Dave.... your Facebook link is down. Where can we find the more complete instructions you posted there?
Thanks
H
Yep, facebook link is definitely down.
I'm ordering the parts to rebuild my tensioner and these infos/pics might come handy.
Last edited by ZBrink; 01-24-2025 at 01:06 AM. Reason: Duplicate messaging already earlier in thread
albeR/To is offline   Reply With Quote
Old 08-09-2022   #32
tiegsd
tiegsd's Avatar
Default Re: Rebuilding The LT5 Tensioner
Great post, going to have to do this soon, super helpful!
1990 Black/Black ZR-1 #1155
Old 08-10-2022   #33
Erik
Looks like Dave hasn't been on in a few months. I hope all is ok with him. Anyone know him in the outside world?
1990 ZR-1 # 996
Old 08-10-2022   #34
A1990
A1990's Avatar
I will reach out to David
Dennis Fierstein
90 ZR-1 #2562 Atomic-Z
ZR-1 Net Registry Treasurer
Old 06-10-2023   #35
ManPro
I attempted this tensioner rebuild and cracked my back casing on the factory LT5 Tensioner while trying to tap the fresh tension spring in. I've called all around and nobody has a used/core available for sale.
I just installed a slew of new parts including injectors, radiator, ignition coils, starter, cam sensor, and knock sensor to get my ZR-1 Back up and running and now I'm dead in the water since I can't get a replacement tensioner.
Can anyone give me some guidance on how to compress the spring to fit in into the housing? I'm trying to practice installing the spring back in the L98 Donor Part casing, and I've used a vice, and a set of 20" Pliers to try and compress it and no matter what I do I can't get it compressed enough to fit back into the casing...
ManPro is offline   Reply With Quote
Old 01-12-2024   #36
davids1978
I just finished rebuilding my tensioner with these instructions and a L98 tensioner purchased from Amazon - fairly straightforward task.
ManPro - I ended up putting the spring in a vice with half of the width of the spring exposed. This allowed me to compress it enough to get the cover started. Once you get it started you can remove it from the vice and use a pair of channel grips to fully seat the spring.
davids1978 is offline   Reply With Quote
Old 04-07-2024   #37
ZBrink
Forum Chairman
ZBrink's Avatar
Does anyone have the current part # for the L98 tensioner? Everyone seems to be out of stock of the Dayco 89298 which makes me think it may have been discontinued. Or, does anyone know of another tensioner that has the same "guts"?
Zack Brinkmeier - Forum Chairman, ZR-1 Registry
forum@zr1netregistry.com
1990 ZR-1 #299, Bright Red/Red
Old 04-07-2024   #38
A bit pricey but?
https://www.ecklers.com/1988-1991-co...B&gclsrc=aw.ds
Old 04-09-2024   #39
geezer
Ecklers claim this to be correct for LT5. Can anyone confirm this??
(Ecklers current in-stock tensioner does NOT fit the LT5, you can however use the guts to rebuild yours - ZBrink)
geezer is offline   Reply With Quote
Old 04-09-2024   #40
Link I posted is pulleys for L98.
