04-05-2023 | #1 |
Secondary fuel pump dead?
Car runs fine, except when at full throttle going through the gears. Then acts like fuel shutoff. For short bursts of full throttle, everything is ok. I'm thinking the secondary pump isn't keeping up, or only the primary is working.
Sent from my Pixel 4a (5G) using ZR-1 Net Registry mobile app
1992 ZR1 #442, 2 tops, White, White, Haibeck 415, 3.90 gear, Coilovers 2018 Audi RS5, 2.9 V6 Twin Turbo, Auto, Black, Black 2021 Audi Q3, 2.0T, 8 spd Tiptronic, Navarro Blue metallic, Pearl Beige |
04-05-2023 | #2 |
Re: Secondary fuel pump dead?
Most likely yes. To confirm perform the fuel pumps amperage test on the red pigtail at the wiper motor. Your meter will read 7-9 amps if both are running. 3-4 amps if one is running. Details in the Stickies.
04-08-2023 | #3 |
Do you still have the Secondary Port Throttle (SPT) system still in place?
If so, test the vacuum pump and each of the vacuum actuators. A failure of any 1 of those 3 items can cause the same symptom.
04-08-2023 | #4 |
Secondary Port Throttle (SPT) system is still in place. Entire system was checked by Marc when my 415 was built less than a year ago. Vacuum pump doesn't cycle at all. Pretty sure its a pump. Will be replacing both today.
04-08-2023 | #5 |
My first check was the current draw. Current reads 9.3 Amps, so it seems both pumps are running.
Next check will be fuel pressure.
1992 ZR1 #442, 2 tops, White, White, Haibeck 415, 3.90 gear, Coilovers 2018 Audi RS5, 2.9 V6 Twin Turbo, Auto, Black, Black 2021 Audi Q3, 2.0T, 8 spd Tiptronic, Navarro Blue metallic, Pearl Beige Last edited by Subfixer; 04-08-2023 at 06:22 PM. |
04-08-2023 | #6 |
Fuel pressure check.... not good.
Only 42psi at cold idle.
04-08-2023 | #7 |
I really am disappointed in aftermarket Chinese parts.
After replacing both pumps with Delphi FE0039 units, I now have a combined fuel pressure of 20psi.....
04-08-2023 | #8 |
If the vacuum pump doesn't cycle at all, how do you know if it is still working?
04-08-2023 | #9 |
Vacuum pump does cycle, just not excessively. About once every 45 seconds after initial pump up.
Put old (original) fuel pumps back in for now. After removing and replacing the assembly 3 times, I'm now an "expert".
04-08-2023 | #10 |
Any recommendations for "good" fuel pumps?
