![]() Join Date: Mar 2018
Anyone selling a finished ported top end (plenum, throttle body, injector housing) for our 94 ZR-1?
Might be interested in stock parts too since sending our cores Norway-USA-Norway to have them machined is very poor business. All tips and input is highly appreciated, thanks. (Pic for attention).tapatalk_jpeg_1537018294348.jpg Sent from my SM-G955F using ZR-1 Net Registry mobile app
Roy Martin 1994 ZR-1 #112 Admiral Blue/Black Dana 4:10 Aluminum flywheel Corsa exhaust Watson headers Haibeck chip 470 HP/399 RWHP 1991 ZR-1 #400 White/Red (SOLD) Dana 4:10 Powder coated engine Haibeck performance chip Borla exhaust Last edited by ZBrink; 01-19-2025 at 11:36 AM. Reason: Title Edit |
![]() Join Date: Aug 2017
I have stock injector housing with coolant tubes and throttle body if you want to buy as cores and ship to who ever does the porting.
#3 | |
Roy Martin 1994 ZR-1 #112 Admiral Blue/Black Dana 4:10 Aluminum flywheel Corsa exhaust Watson headers Haibeck chip 470 HP/399 RWHP 1991 ZR-1 #400 White/Red (SOLD) Dana 4:10 Powder coated engine Haibeck performance chip Borla exhaust |
Sorry The injector housing I have are from a 91 but if your port them and use aftermarket injectors it will fit a 93-95. I have plenum from 91 but the top where the cable is is different but you can make it work on a 93-95
![]() Join Date: Dec 2003
I can probably furnish all the parts you want ported and send them to the person you would like to do the work or I can select shop for you. After porting, powdercoat if desired, then ship all to you.
Jerrys Gaskets contact me by email, store.jerrysgaskets@gmail.com
![]() Join Date: Nov 2011
I think Jerry's offer is a great way to go.
#7 | |
