![]() Join Date: Dec 2005
Took my 1990 out today, was running great. After about a half hour of driving when coming to a light to stop, petal went way down before the brakes engaged. Brake light on for a short time. Petal felt strange. Brakes seemed to work after that but then it happened again after about 6 or so more stops. Fluid in the two reservoirs are where they should be.
Any thoughts on what may be causing this? Thanks in advance.
1968 convertible Lemans Blue, 1986 coupe Medium Blue NCRS Top Flight (sold), 1990 ZR1 #2529 Red NCRS Regional and National Top Flight (sold), 1990 ZR1 #2124 Charcoal Metallic NCRS Top Flight 2010 & 2018, 2003 Anniversary Red Convertible (sold) |
#2 | |
![]() Join Date: Sep 2016
Install a new master cylinder immediately. Do not drive it anymore.
Two questions. Why do you think it is the MC rather than the booster? Any idea where you can find a new MC or have this one rebuilt? Rockauto are mostly out of stock.
#5 | |
Thanks.
#6 | |
I hope it's the master cylinder as those are easier to find and the 4 bolt vacuum boosters are a bear to find.
Booster is an assist and has nothing to do with the height of the pedal. The pedal went down because fluid escaped past the pistons in the master cylinder. That causes the light to come on. It happened to me once, right before my favorite twisties. O Reillys has a master cylinder for you for under $150.00. Brakes are life and death and thus my abruptness brother.
#8 | |
![]() Join Date: Jul 2016
Tricky part of the MC replacement is the C-clip from the pedal to the rod. You?re upside down with your head in the footwell and it?s dark even with a good light. Be patient, it will work.
#10 |
If the booster is good to go then the master cylinder is the culprit. Looks like you are in good hands advise wise. GC
