06-28-2022 | #1 |
Plan. B if I can't get Amsoil Z-Rod?
My car will be going in for some servicing the first of next week, and I don't think I'll be get Z-Rod by then.
I was looking for the High Mileage Mobil 1 at the local Wal-Mart, and all they had was 0-20 and 5-30. Being in Canada, some of the smaller brands that can be bought in the US aren't easily available up here. Any plan B recommendations? Oils that would do lesser harm? Or am I overthinking it and any quality synthetic of appropriate weight would work ok for the time being.
06-28-2022 | #2 |
Re: Plan. B if I can't get Amsoil Z-Rod?
Before I switched to Amsoil and after Mobil quietly reduced Zn and Phosphate level, I ran standard Mobil 1 10w 30 and added a half a bottle of ZDDP. Of course, no way of knowing if it helped or not was impossible. Nonetheless, put my mind at ease?
06-29-2022 | #3 |
Find out if you can get this one https://products.liqui-moly.com/oils...-10w-40-1.html
I think it's sold in Canada. It's a top notch German producer (actually not just the brand is German but it's MADE here) and that juice is optimized for engines that require a good chunk of heavy duty lubrication - as ours do. No voodoo, just science I use Liqui Moly on all my cars and have been doing so for more than a decade. No issues so far.
ZR-1 #638/1991 |
06-29-2022 | #4 | |
I agree with you. A lot of people don?t know or trust Liqui-Moly, but that?s what I have been using in all my cars too. I?m going to try their oil for my Harley too. Top grade German engineering and science. Sent from my iPhone using ZR-1 Net Registry
06-29-2022 | #5 |
I use Royal Purple 10w-40 which also has zinc and got the approval from Marc Haibeck. JPEG_20220629_121154_5789866720562514169.jpg
Sent from my SM-G955F using ZR-1 Net Registry mobile app
Roy Martin 1994 ZR-1 #112 Admiral Blue/Black Dana 4:10 Aluminum flywheel Corsa exhaust Watson headers Haibeck chip 470 HP/399 RWHP 1991 ZR-1 #400 White/Red (SOLD) Dana 4:10 Powder coated engine Haibeck performance chip Borla exhaust |
06-29-2022 | #6 | |
I am using Mobil 1 Formula M 5w 40 motor oil purchased from Napa. There is a QR code scanner on the label to confirm authenticity. It is the same mineral content at the 5w 50 as tested here. https://youtu.be/i3pNHfxKAJc
1993 ZR-1 #211 Yellow On Beige Beast #2 1992 ZR-1 #427 Black On Black *Sold* 1985 L98 Blue On Blue *Sold* |
06-29-2022 | #7 |
I run Joe Gibbs Driven hot Rod racing oil HR4 in mine. 10w-30.
Dennis Fierstein 90 ZR-1 #2562 Atomic-Z ZR-1 Net Registry Chairman of the Board ZR-1 Net Registry Treasurer |
06-29-2022 | #8 | |
Thanks!
06-29-2022 | #9 | |
https://www.amazon.ca/Rislone-ZINC-Z...jaz10cnVl&th=1
06-29-2022 | #10 | |
