05-20-2022 | #1 |
Won't go into 1st gear sometimes at a red light
I was wondering if anyone else has experienced this and can maybe point me in the right direction? Most of the time I roll up to red lights, I'll be in neutral. When the light turns green I put the clutch in and move shifter into 1st gear like normal and then proceed to go. But sometimes (randomly) I'll be sitting there in neutral, then put the clutch in and it will not go into 1st gear. I then have to quickly put the clutch in, put the shifter in 2nd, then when the car starts rolling I can quickly clutch in and it'll slide right into 1st gear?
Its effective but extremely annoying. Anyone have any ideas? Jay Trager |
05-20-2022 | #2 |
Re: Won't go into 1st gear sometimes at a red light
Sounds like the clutch is not fully disengaging or dragging a bit.
05-20-2022 | #3 |
Stock clutch? Or has it been replaced?
I used to have that ?problem? frequently when a single mass flywheel was in the car. Then my pilot bearing went bad and replaced everything and it?s pretty much gone away. However, I do recall seeing a note in the owners manual that gives a procedure of what to do when this happens?so it must be a common enough ?problem? for GM to have put it in the owners manual from the beginning. Sent from my iPhone using ZR-1 Net Registry
'90 #413 Red/Red Sold '90 #1583 Red/Red |
05-20-2022 | #4 |
Try putting it in second after coming to a stop, then it may find first more easily.
05-21-2022 | #5 |
What is the history on transmission oil service and what are you using now?
05-21-2022 | #6 | |
I believe the clutch is stock and I know there is the lighter weight aluminum flywheel. Jay |
05-21-2022 | #7 |
If you have not already, I would suggest a call to Marc Haibeck about it. If he recently worked on it that is a plus as he will be familiar with the car. He is always willing to help ZR-1 owners and I am sure he could offer some sound advice.630-458-8427. --Bob
05-21-2022 | #8 | |
That is great news if Marc had his hands on it; it must be good to go. As Bob said, reach out to Marc the Wizard as he know all the symptoms of these cars. Best wishes. Mine does that too once in awhile on my 95 with 31K miles. When it does, I just go into another gear then to first. I even remember doing the same with my old school hot rods with Muncie M-21 so I never thought much about it. Sent from my iPhone using ZR-1 Net Registry
05-21-2022 | #9 |
Yes, I'll reach out to Marc for opinion as well... good feedback everyone, I appreciate it!
Jay |
