Old 03-29-2022   #11
Jagdpanzer
Jagdpanzer's Avatar
Default Re: Ideal size for aftermarket wheels?
285/35-18 up front, 325/30-19 on back
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 03-29-2022   #12
I second.
Old 03-30-2022   #13
Fully Vetted
Fully Vetted's Avatar
How much speedo correction do you have to make with 19's in the rear? After really struggling to find tires for my Shelby Series 1's I'm thinking of a change as well.
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
Old 03-31-2022   #14
HAWAIIZR-1's Avatar
Default Ideal size for aftermarket wheels?
It depends of what size tires you decide on in 19?. Here is an example using the tire calculator to get as close as possible to stock size overall diameter.
https://www.tyresizecalculator.com/
https://tiresize.com/speedometer-calibration/
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 03-31-2022   #15
With 325x19s, my speedo is 3mph too high at 70-80mph.
Old 04-01-2022   #16
HAWAIIZR-1's Avatar
Dom, Do you use a GPS speedo and compare it to your car speedo to figure out the difference?
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
Old 04-01-2022   #17
Jagdpanzer
Jagdpanzer's Avatar
I use a speed app on my IPhone.
With the speed sender gear set I have installed the the speedometer error is within 1 mph of actual at 65-75 mph of road speed.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 04-02-2022   #18
HAWAIIZR-1's Avatar
Cool! I have one one my phone that I have clocked the bullet train here at 186 mph. I will try to check mine one day.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
Old 04-02-2022   #19
Yes I do. Its pretty consistent 3mph difference(actual is lower) when at indicated 70-80mph, which is close enough for horseshoes and hand grenades. 🤣🤣
Craig, I also used the GPS to measure TGV going under English Channel at 311kph. Why the hell we don?t have trains like that here is a crime.
