Old 03-25-2022   #1
Flyman 27
Flyman 27's Avatar
Default FS Single fuel pump conversion for LT5
Have fuel Pump problems? There is a solution! A conversion to a single high performance pump. Invested a LOT of time researching & building one for my ZR-1. Decided to see how much interest there would be in more of them. All stainless construction. High performance Racetronics Turbine Fuel Pump.
Specs & notes:
ZR1 ZR-1 LT5 New Fuel Sending Unit, Single Pump Conversion
? Entire unit made of Stainless steel, No more corrosion!
? All power leads upgraded to 16 gage for cooler running.
? All new High Performance, corrosion resistant Bulkhead.
? All New electrical Connectors upgraded; corrosion resistant.
? Simple plug-n-play installation, you just need to unplug one lead from the ECU, instructions provided.
? OEM single pump capacity = Nom 18.8 GPH @ 5 Amps.
? OEM Both Pumps Capacity = Nom 26.7 GPH @ 10 Amps.
? New Performance pump = max 67 GPH Capacity @ 12 Amps.
? System combines power leads from both OEM pumps to power the single Performance pump, no rewiring required, plug-n-play!
? New Racetronics high performance fuel pump installed.
? New pump is Turbine Type for long, sustained running at full power!
? Noise reducing sleeve installed on pump.
? Rated for up to 550HP at the crank.
? Fuel Supply tube modified for extra flow.
? Includes new tank flange seal/gasket.
I just added all stainless installation hardware to the kit.
These are not cheap to build and they take a couple hours to build. I decided that $400 shipped would be a fair asking price. Please PM me if you have any interest.
Cams by Pete
Old 03-25-2022   #2
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
Default Re: FS Single fuel pump conversion for LT5
Nice!
I like it!
Sold.
PM me payment details.
Thanks,
Marty
Old 03-25-2022   #3
DRM500RUBYZR-1
Dan,
Payment sent via paypal.
YES, it looks beautiful!
GREAT workmanship!
My Ruby should love it!
Thank you,
Marty
Old 03-25-2022   #4
JT ZR-Won
Wow, that is fantastic! Good to know, thanks for posting that
Jay
JT ZR-Won is offline   Reply With Quote
Old 03-26-2022   #5
Matt B
Matt B's Avatar
You should build a batch of them, it looks amazing, provides plenty of volume, should be bullet proof and is plug'n'play. What else do you want?
Great product!
ZR-1 #638/1991
Old 03-26-2022   #6
aafc
aafc's Avatar
Very nice,
I would like one. I was going to due this mod, but you have made it
happen. PM me information on how to pay.
1990 white/black #2546
one of a few 4l8OE EQ ZR-1's
Old 04-06-2022   #7
Flyman 27
Flyman 27's Avatar
These are in stock and available for immediate shipment!
Cams by Pete
Old 04-09-2022   #8
aafc
aafc's Avatar
Dan,
have a question on the single fuel pump conversion. PM me.
JOHN
Old 04-17-2022   #9
Flyman 27
Flyman 27's Avatar
These are available for immediate shipment.
Cams by Pete
Old 04-20-2022   #10
DRM500RUBYZR-1
Have not installed it yet.
TOO Busy ADMIRING it!
I just might buy another for display purposes only.
The execution is FLAWLESS!
True Auto ART!
You just might say that I like it.
Arrived in 48 hours!
Well done all around!
Thank you,
Marty
