Old 03-06-2022   #791
Roadster
Roadster's Avatar
Default Re: TB removal and then some!!!
Originally Posted by Mystic ZR-1 View Post
Where does the fitting for the pre-luber screw in?
Hmm? Could an Accu-Sump be hooked up there, to have the benefit
of pre-oiling on every start up?
https://www.merlinmotorsport.co.uk/k...-they-work-281
Where the oil pressure sensor screws into...if you use your Z on a consistent basis....I would imagine that there wouldn't be any need for an Accu-Sump.....JMO....
Sent from my SM-G981U using ZR-1 Net Registry mobile app
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 03-06-2022   #792
Roadster
Roadster's Avatar
Need some info on removing the bolt from the front sway bar bracket that attaches to the LCA....this bolt won't budge either with electric impact or tapping the bolt out with a small sledge....so before I do any damage... does this bolt slide through the bushing sleeve...(which I'm thinking)...or is it threaded through....
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 03-07-2022   #793
garyhugo
garyhugo's Avatar
If that is the upper stabilizer bar insulator then yes it slides through the sleeve.
Gary
90-1572
garyhugo is offline   Reply With Quote
Old 03-07-2022   #794
Roadster
Roadster's Avatar
That is the lower part of the bracket Gary....attached to the LCA and found out that it also slides out.... thanks...[emoji16][emoji16]
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 03-09-2022   #795
gtcollins@maxnet.co.nz
gtcollins@maxnet.co.nz's Avatar
Get a cheap socket put the head of the bolt in the socket and hammer it once it starts to move you should be able to get it out the rest of the way
Sent from my SM-T865 using ZR-1 Net Registry mobile app
gtcollins@maxnet.co.nz is offline   Reply With Quote
Old 03-13-2022   #796
Roadster
Roadster's Avatar
Back on the ZR-1 this afternoon...
finally got the sway bar bracket removed....did a preliminary cleaning of the LCA and the bracket after a short soak....bracket is in for more soaking...getting there....20220313_165622.jpg20220313_165658.jpg20220313_170222.jpg20220313_153741.jpg20220313_153749.jpg20220313_155641.jpg
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 03-16-2022   #797
Roadster
Roadster's Avatar
Can't tell you the number of times I have stripped...sanded and resprayed and then clear coated the plenum over the last almost 4 years..... I know I could have got it powder coated...but also like the feeling of do as much as I can myself....so after repainting the plenum months ago.... today I finally clear coated this piece once again....may not be perfect... but looks good enough to install...
also the LS sway bar bracket after soaking for a few days in Evapo-Rust....paint literally just wiped off....liking the bare metal finish. .especially in the comparison pics.....may leave as it and just clear coat....[emoji16][emoji16]20220316_115755.jpg20220316_115741.jpg20220316_122910.jpg20220316_121026.jpg20220316_121040.jpg
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 03-17-2022   #798
This thread just hit 80 pages--Is this a Forum record? Been a fun thread to follow. --Bob
Old 05-01-2022   #799
Roadster
Roadster's Avatar
Thanks Bob....it has been fun....[emoji16][emoji16]
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 05-01-2022   #800
Roadster
Roadster's Avatar
Been extremely busy recently...not totally ZR-1 related...as our "new" Yellow 74 Convertible came home last week...and our Brown 74 Convertible went down to GA for some engine work....which now leaves time to devote fully to the 94....always something going on....[emoji16][emoji16]
Pic #1....still need more cleaning and painting to finish....was thinking about removing the cam covers for painting....but might just tape everything off and paint them on the engine....
Pic #2.....our "new" 74 Convertible is home....while not cosmetically perfect....the L-82 is rebuilt and all new suspension in place....
Pic #3...our 74 LS4 454 loaded and now in GA for some engine work.... no return time frame...so now full concentration for the ZR-1....[emoji16][emoji16]20220501_102136.jpg20220427_211739.jpg20220427_054108.jpg
1974 LS4 454 Vert
1974 L-82 355 Vert.
