#771 |
![]() Join Date: Mar 2014
I have another question....although I am not or have intentions to get the Z judged....I have cleaned up the upper control arm attachment bolts...it seems like they were painted...so were they painted from the factory or are they supposed to be their natural finish as shown in the pics???
Guess I just can't help myself...cleaning everything I get my hands on...the pics.... Pic #1...one bolt cleaned...one uncleaned.... Pic #2...another view... Pic #3...cleaned....natural finish... Pic #4...another view with some of the attaching spacers....all cleaned up... Pic #5...I'll refer to this as the lower control arm plate... crud for sure on both sides... Pic #6...the reverse side pictured and entire plate and bolts cleaned and ready for reinstall.... 20211219_113717.jpg20211219_113711.jpg20211220_103441.jpg20211220_105941.jpg20211218_155743.jpg20211218_162159.jpg Sent from my SM-G981U using ZR-1 Net Registry mobile app
#772 |
Had mine out last year and they were not painted.
Your 94 Z is one of the few I've seen with with aluminum spring protection guards installed. Apparently GM gave up on installing these at the factory for the last two years of production. My 94 was also missing these but was lucky enough to find a NOS set that are on the car now. Sent from my iPhone using ZR-1 Net Registry
#773 | |
As far as the shields go....maybe because mine is a very early production 94 is why they were installed....
#774 |
Been working on the 74 lately... but this afternoon decided to give it a try once again to remove the lower control arms on the 94....so finally success.... broke the bolts loose and got the front bolt out....the rear bolt is another story....so if anyone can refresh my memory on the secret to getting that bolt out...it would be greatly appreciated.... I think there was a post on exactly that...but having a hard time finding it....
as you see in the pic it is hitting that part of the underbody....is there something else that needs to be removed.... Thanks for any info.... 20220206_181016.jpg Sent from my SM-G981U using ZR-1 Net Registry mobile app
#775 |
![]() Join Date: Mar 2015
Hi Tom you have to remove the K frame or cut the bolt when you put it back in turn it around
Glen Sent from my SM-G998B using ZR-1 Net Registry mobile app |
#776 | |
#777 |
Hi Tom it's not hard to remove the K frame just one side at a time two front bolts one engine mount nut two rear maybe three rear
#778 |
Thanks Glen....I will take a look....[emoji16][emoji16]
#779 |
Back working on the ZR-1 today and checking out the front cross member brace....could use some advice or suggestions on the driver's side brace....as I may be missing something.... I'm at a loss for moving further....as you can see in Pic #1...how do you get to the top 13mm bolt to loosen.... in Pic #2... got the bottom 15mm bolt out and that top one is now loose...and seeing that another bolt that also needs to come out in the top middle of the brace....obviously when I get the braces removed....gives me more access to also cleanup and tighten the oil pan bolts....
Thanks for any info...IMG_17311.jpgIMG_17301.jpg Sent from my SM-G981U using ZR-1 Net Registry mobile app
#780 |
Hi Tom you can buy Wrenchs like these one long spanner for cracking the locked thread and ratcheting spanner for undoing the bolts when you can't get a socket and strong arm onto it if you need anymore help sing out
Glen 20220214_180422.jpg Sent from my SM-G998B using ZR-1 Net Registry mobile app |
