01-04-2022 | #1 |
More Whoa Power
Must have been a good boy last year.
Santa dropped off a set of Baer 14" 6 piston disc brakes. Parking brake is incorporated in the rear disc center hats. Same hardware as used on C5 & C6 Vettes. Kit included longer parking brake cables, braided SS flex lines and fittings. Can't wait for the snow to go away so I can try them out. IMG_2614.JPG IMG_2620.JPG IMG_2627.JPGIMG_2625.JPG Sent from my iPhone using ZR-1 Net Registry
01-04-2022 | #2 |
Re: More Whoa Power
Looks great! What rims are you finishing it off with? I recently installed C6 zo6 brakes and am still on jack stands waiting on the fiskes to arrive....
01-04-2022 | #3 |
Re: More Whoa Power
Cool would like to know the difference have been thinking of this myself
Glen Sent from my SM-G998B using ZR-1 Net Registry mobile app |
01-04-2022 | #4 | |
Re: More Whoa Power
18/19 Fikse Profil 10s IMG_0977.JPG Sent from my iPhone using ZR-1 Net Registry
01-04-2022 | #5 |
Re: More Whoa Power
So you got them for Christmas and already both
front and rears are installed, wheels/tires back on, up and running? I'M IMPRESSED! Look FANTASTIC! Congratulations! PS: More info about the rears, especially the parking brake setup. Did you have to change the knuckles?
1995 ZR-1 #106 Blk/ Blk Owned by me since 2000. 93K miles, but not on motor :-) Mods the way I want it, Not afraid to drive it! Last edited by tf95ZR1; 01-04-2022 at 09:31 PM. Reason: Wanted 2 |
01-04-2022 | #6 |
Re: More Whoa Power
Awesome Phil.
I have the same rotors with 4 piston bears on the front and 12.8 4 piston wilwoods on the rear. I used a wilwood proportioning valve to balance it. really nice upgrade, will pull your eyes out. The limiting factor became the tires.... need more tire now. you will love them John |
01-04-2022 | #7 |
Re: More Whoa Power
As always, impeccable work!
01-05-2022 | #8 |
Re: More Whoa Power
The original caliper mounting plate
is replaced by a Baer provided bearing retainer/parking brake assembly that fits between the suspension knuckle and wheel bearing hub. This assembly is also the mounting point for the brackets which the calipers mount to. The parking brake is a one piece circular shoe expanded by a single mechanical actuator when the parking brake is pulled. The brake drum is incorporated in the disc rotor hat. IMG_2633.JPG Original caliper mounting plate (not used) IMG_2631.JPG Baer bearing retainer/parking brake assembly IMG_2630.JPG IMG_2636.JPG Parking brake assembly with disc rotor removed IMG_2633.JPG Parking brake Actuator IMG_2637.JPG Actuator Cable attachment IMG_2634.JPG Parking brake drum Sent from my iPhone using ZR-1 Net Registry
01-05-2022 | #9 |
More Whoa Power
01-05-2022 | #10 | |
Re: More Whoa Power
wow, those look awesome and it's cool retaining the hub emergency brake for less hassle. Bring er out to katies!! looking good.
95 390 LPE ZR1 (505 rwhp) LSV = Lingenfelter Super Vette Twin Turbo 2003 Z06 (800 RWHP) |
