11-06-2021 | #1 |
Brake upgrades
Without breaking the bank with Brembo or Baer brakes etc, is the cost of a C5 conversion kit worth the $$$ over slotted and drilled rotors with quality pads as a direct replacement for the original rotors?
Here is an example of the latter: https://www.ecklerscorvette.com/1988...ails_tab-title Sent from my SM-G955F using ZR-1 Net Registry mobile app
Roy Martin 1994 ZR-1 #112 Admiral Blue/Black Dana 4:10 Aluminum flywheel Corsa exhaust Watson headers Haibeck chip 470 HP/399 RWHP 1991 ZR-1 #400 White/Red (SOLD) Dana 4:10 Powder coated engine Haibeck performance chip Borla exhaust |
11-06-2021 | #2 |
Re: Brake upgrades
J55s are pretty good, in a 1991 Test they did 155 ft from 70, thats with old tech tires and pads. A c7 corvette can pull it down from 70 in 130-135 feet with big Brembos.... so take a 91 Z with J55s add in good pads, bias spring, and new modern tires you are not far off pace... repeated stops or on the track you will see a difference but daily driving the J55s are nice.....
https://www.caranddriver.com/reviews...mparison-test/
11-07-2021 | #3 |
Re: Brake upgrades
Doug Rippie bias spring
Power Stop Z23 or Z26 pads Stainless brake flex lines High temp fluid Russell speed bleeders Master and calipers fresh Do a clean up cut on stock rotors 300 wear rating tires The engineers did a good job. You will surprise yourself what it can do on the street and on mountain roads. My practical nature says use stock to its maximum potential.
11-07-2021 | #4 | |
Re: Brake upgrades
I would think upgraded rotors in combo with said parts would be even better than cleaned up stock ones..? https://www.powerstop.com/product/po...ior-brake-kit/ Sent from my SM-G955F using ZR-1 Net Registry mobile app
Roy Martin 1994 ZR-1 #112 Admiral Blue/Black Dana 4:10 Aluminum flywheel Corsa exhaust Watson headers Haibeck chip 470 HP/399 RWHP 1991 ZR-1 #400 White/Red (SOLD) Dana 4:10 Powder coated engine Haibeck performance chip Borla exhaust Last edited by Norwegianmopar; 11-07-2021 at 06:15 AM. |
11-08-2021 | #5 |
Re: Brake upgrades
Thumbs up for power stop Z26 drilled/slotted rotors plus matching pads. Following the recommendation of the brotherhood I upgraded my 30 years old stock brake system and it works great. No noise (I mean NO) and very little brake dust (yet more than on quality ATE Ceramic Pads). Brake dust is grey so you don't recognize it too much on argent wheels.
Brake force is good, yet the modulation can not keep up with modern cars to my opinion. You get what you pay for, i.e. heavy brake power will need heavy leg power as input, still. Neither is it as sensitive / giving good feedback like a modern brake. But the overall stopping power is great and does THE BEAST justice. Braided hoses probably improve the feel. They're on my list.
ZR-1 #638/1991 Last edited by Matt B; 11-08-2021 at 04:33 PM. |
11-08-2021 | #6 |
Re: Brake upgrades
Thanks for the reply. Looks like the way to go.
I think I will add these from DRM since I already consider the DRM coilovers : https://www.dougrippie.com/c4-corvet...el-brake-lines https://www.dougrippie.com/brake-bias-spring Sent from my SM-G955F using ZR-1 Net Registry mobile app
11-09-2021 | #7 |
Re: Brake upgrades
I'm also thinking about the DR spring... Does he ship to Europe?
Sent from my SM-G991B using ZR-1 Net Registry mobile app
ZR-1 #638/1991 |
11-09-2021 | #8 |
Re: Brake upgrades
I went with Wilwood six piston narrow lights calipers up front and c5 four piston calipers for the rear with front and rear Baer eridaspeed 3 piece rotors. DONE!
Here is the money shot on the rear
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 11-09-2021 at 03:24 PM. |
11-09-2021 | #9 |
Re: Brake upgrades
Wilwood 6 pistons up front and Wilwood 4 pistons rear with Mr. Parker?s parking brake set up.
http://www.zr1.net/forum/showthread.php?t=24546 |
11-09-2021 | #10 |
Re: Brake upgrades
