Old 09-27-2021   #1
Default Random stall when coming to idle
So I have been fighting with a stalling issue. If I am coming to a stop, I usually put it in neutral and coast as I slow down. Every once in a while, the car will stall. Just drop out. It will restart and be fine, usually for the rest of the drive. Just not sure where to look next.
I have:
New O2 sensors
New injectors
New coils
New wires
Plugs are about a year old
New fuel filter
Phil's fuel regulator
I don't seem to have any vacuum leaks
Fuel pressure is solid
Outside of the stall when coming to idle the car runs great
Thoughts on where to look next?
Old 09-27-2021   #2
wfot
wfot's Avatar
Default Re: Random stall when coming to idle
possibly the idle control motor?
could been old
or could just be dirty.
wfot is offline   Reply With Quote
Old 09-27-2021   #3
BlackZR1
BlackZR1's Avatar
What are your IAC counts at idle?
If you are much higher than 10 it suggests your throttle is closed too much and you are relying on the IAC to keep the car from stalling.(Yes the IAC regulates idle speed but the min. throttle hard stop setting should be high enough to keep the car running just below idle rpm target with 0 counts.)
I went through this last month and followed the procedure by XfireZ51 here:
http://zr1.net/forum/showthread.php?p=261060#post261060
Have not had a problem since.
Roger
1990 ZR-1 #2699
Black on Black
15,000 miles
Full-time secondaries, 4.10 gears, C-beam plates, ported top end
BlackZR1 is offline   Reply With Quote
Old 09-27-2021   #4
IAC was swapped with no change. I did the IAC procedure a couple times. I may need to go through it again but IAC counts are 10 or less fully warm (no AC)
Old 09-28-2021   #5
Jeff, you might check with Marc or stop in to see him. I had this stalling problem shortly after he did his 510 package on the '95 and as I recall he just made a minor adjustment to the throttle cable at the front of the engine. I may be wrong, as it was several eyars ago, but that is what I recall.--Bob
Old 09-28-2021   #6
Thanks Bob,
I have been chatting with him as well.. it happening less now.. time
Will tell
Old 09-28-2021   #7
1991 Corvette ZR-1
MAP line all clear? This was what stalled mine under the same conditions you?re describing.
Old 09-28-2021   #8
Yes
Old 09-28-2021   #9
Young1
Young1's Avatar
My car did than when the camshaft position sensor was bad. Check for codes. I think it is 31?
Steve Young
Second Owner
SOLD
SOLD
Old 09-29-2021   #10
Yeah no codes present. But interesting issue with cam sensor
