Old 03-06-2021   #631
JG95ZR1
JG95ZR1's Avatar
Default TB removal and then some!!!
It?s a filter that can only be changed if you remove the valve covers. They are usually very brittle so I would poke at them. Jerry?s sells them.
https://www.jerrysgaskets.com/filter...ent-90-95-1b4/
JG95ZR1 is offline   Reply With Quote
Old 03-06-2021   #632
Roadster
Roadster's Avatar
Default Re: TB removal and then some!!!
Thanks for the info....think I'll pick one up just to have...this one is still very moist....
Sent from my SM-G981U using ZR-1 Net Registry mobile app
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 03-06-2021   #633
Roadster
Roadster's Avatar
Pic #1....during the cleaning phase... that crud was caked on there...tough to remove....
Pic #2....cleaned and removed "o" ring....it did clean up good after this pic and is still very pliable...but I will probably replace...
Pic #3....LS head is cleaned...still plenty of cleaning to do...obviously much more accessible with everything out of the way....20210306_173206.jpg20210306_174306.jpg20210306_174331.jpg
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 03-07-2021   #634
Roadster
Roadster's Avatar
FYI....which may be common knowledge already....the pic shows the gear to cooler hose... what I found out is there is not a specific hose out there for the ZR-1 VIN J....but it appears that the VIN P hose is exact and IMO actually works out better as it is 18" in length...our hose in the pic is only 9" long...so a benefit for us...as all we need to do is cut to length...and therefore no need to make a custom hose and connector....
In the second pic....this is the clamp that attaches the hose to the cooler line....don't know if this clamp can be reused....or where to purchase....[emoji16]20210307_102652.jpg20210307_102702.jpg
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 03-07-2021   #635
Roadster
Roadster's Avatar
Just got back from Auto Zone....they have the pump to reservoir hose by Duralast that is 36" long .. obviously you can do a few vehicles with it....they also have it by the foot....but it did not seem as strong as the packaged hose...the loose one felt like it would be prone to kink or even collapse under use....JMO...
The hose from the pump to the cooler is 3/8" and using fuel line hose which feels just as strong as the one its replacing....also ordered the VIN P gear to cooler hose online through another vendor....and will cut to fit....
The Duralast feels as strong as the original pump to reservoir hose...in that it will hold its shape in use....20210307_134019.jpg20210307_134028.jpg
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 03-07-2021   #636
In the second pic....this is the clamp that attaches the hose to the cooler line....don't know if this clamp can be reused....or where to purchase....[emoji16]Attachment 14816Attachment 14817
I think those may be PEX crimp clamps. I don?t think they can be reused.
No sure of size but link is for 3/8?.
https://www.ebay.com/sch/i.html?_fro...lamps&_sacat=0
Old 03-09-2021   #637
Roadster
Roadster's Avatar
Will check them out.....thanks for the link....
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 03-10-2021   #638
Roadster
Roadster's Avatar
Gear to cooler VIN P hose came just a few minutes ago with the new rack...
Hose is a perfect match for our VIN J...screwed into the old rack perfectly...making sure it fits...no need to make new connections...also attached with PEX clamp at the top...just cut hose to size and add PEX clamp to the cooler tube end...and back in business... 20210310_145022.jpg20210310_144121.jpg
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 03-10-2021   #639
Roadster
Roadster's Avatar
Unboxed the rack to check it out...everything looks good...only disappointment was that it did not include tie rod ends like was shown in the ad....will check it out...but probably get 2 new ones....most likely the greasable type...20210310_211642.jpg
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 03-11-2021   #640
Unboxed the rack to check it out...everything looks good...only disappointment was that it did not include tie rod ends like was shown in the ad....will check it out...but probably get 2 new ones....most likely the greasable type...Attachment 14844
What did the vendor say about the advertised tie rod ends?--Bob
