#41 |
![]() Join Date: Mar 2014
Hello Jamall.....I am also going to change out the hoses on mine....I found a high pressure hose...from the pump to the gear........are you changing the cooler assembly outlet hose from the pump to the cooler... the gear outlet hose assembly from the gear to the cooler.....and the reservoir hose to the pump???
Also did you use metric crow's feet to undo the connections to the gear??? I have the front sway bar out....but don't want to undo the cooler until I undo the gear connections.....any tips will be appreciated.....thanks... ![]()
Tom 1994 ZR-1 #009 "captured test fleet car" 1974 LS4 454 Vert 1974 L-82 355 Vert. 1982 L83 CFI...now a retired "dd"....Sold WAZOO Member Last edited by Roadster; 03-03-2021 at 10:31 PM. |
#42 | |
For the fittings, I actually used a regular adjustable wrench, I just made sure it was as snug as possible. I will say I tried a crow foot 17mm which was too small and then a 19mm which was too big. So the one crow foot wrench I needed, the 18mm, I lost somewhere. I have a set of line wrenches in standard measurement and they fit on every other fitting on this car, except for the fittings on the rack. 5/8 line wrench will fit great on the high pressure hose fitting going into the pump. I do not think you can successfully get to all the connections without removing the unit from the engine. The angles you need to get a wrench on fittings and apply leverage pretty much impossible in car. Even with taking some of the side skirt off, at least that was the case for me. And I tried to cheat by gently negotiating the PS assembly into the space the rack was after the rack had been removed and I gave in to do it the right way and drained the coolant. This is the part I got stuck on. The driver side coolant tube has to be removed along with the elbow hose to make room for pulling the PS assembly up and out. The torx bolts would not budge and one started to show signs of stripping. I hate dealing with them, so I wussed out and sent mine to Pete to get them out. He sent me a pic of the aftermath ...it made me glad I did not double down on trying to remove them. Last edited by 1991 Corvette ZR-1; 02-23-2024 at 10:34 PM. |
#43 | |
#44 |
If you are talking about the large bolt securing the rack, I did not bother that one until the cooler was out of the way. The wrench size appears to be 18mm for that fitting going to the rack from the cooler. There are four 10mm bolts holding the cooler on. It is pretty light once you undo the last bolt and I kept mine level taking it off to set aside. You may not have to remove the cooler, just the line from the rack. I removed my cooler because I wanted to also remove and clean the bar assembly the cooler bolts to. As long as you remove the fitting from the rack, you can let the cooler hose hang free.
With the cooler line off the rack along with the high pressure hose coming from the PS pump, the only things left are the main bolt and the smaller two bolts on the passenger side. I pulled the rack out through the driver side. The FSM does not state to remove the cooler but I had already introduced air into the system at that point anyway and with it off I had more free room. |
#45 |
No not talking about the large bolt.. I am going to remove the cooler...and I already emptied the PS reservoir....
What I need to know is that there are 2 lines attached to the gear that need to be undone...the ones you used the adjustable wrench on...and there is the line that is attached to the cooler with that onetime hose clamp... How did you go about this...did you undo the cooler and let it hang as you said and then did you remove that hose line with the onetime hose clamp....and then proceed to remove the rack....it appears that I may have to cut a hose....to get the rack out....which would be no biggie.. as I want to replace all of the hoses anyway... Hope this all makes sense.....lol Thx... Sent from my SM-G981U using ZR-1 Net Registry mobile app
#46 | |
I think I follow. I kept all my hoses intact. The cooler hose that has the unique crimp on it was removed from the rack with a wrench but left attached to the cooler. Before I removed the rack, I unbolted the cooler and set aside. |
#47 |
Hit a snag. There?s a dowel pin that rests in a hole in the bottom of the PS housing. Not sure how this interacts with the pressure plate. There are a few slots in the pressure plate. It is the one part of the breakdown I did not take a picture of. Wondering if anyone who has done this rebuild can chime in? I might have to bug Hans.
#48 | |
Thank you again for your tips and suggestions.....the rack is out and I just updated my thread with a load of pics..... ![]() ![]()
#49 |
Still doing little things while waiting for the steering rack to return. Mainly, I am chasing down leaks. Anyone familiar with this as a leak point on the driver side cylinder head? Some special bolt with what looks like gold tint it. Hoping this is something that can be solved in a simple manner.
#50 | |
