Old 02-14-2021   #91
Corvette95
Corvette95's Avatar
Default Re: New C4 Frame Braces
Originally Posted by We Gone View Post
Just installed it on my 91, I set the bars using the toque method set both to 40 foot pounds.
I assume I will understand that when I see the kit/instructions
1994 C4 Coupe Wht/Blk SOLD
1990 C4 ZR-1 Red/Red #0454
Old 02-15-2021   #92
After lots of research on how to adj the bars. Found most info. on CF Post # 55 talks about this method
https://www.corvetteforum.com/forums...-t-work-3.html
Method 1. Adjust by the number of threads counted at each end. It was found that you could have a slight difference in the distance between the brackets from side to side due to GM + or - tolerances when building the car. This can give an unequal tension from side to side.
Method 2. Use the same Toque value on each bar so you have the same tension side to side.
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 02-15-2021   #93
Originally Posted by Corvette95 View Post
Well, think I?m convinced. Gonna order it. Thanks everyone !
Installed about 3 years ago now. Z feels much more solid and planted. I don?t cringe going over RxR crossings.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 02-16-2021   #94
Corvette95
Corvette95's Avatar
Haven't had a return call or email from vette2vette to order the kit.
Old 02-16-2021   #95
When did you call? I know some parts of Illinois got hit with 16-8" of the fluffy white stuff
Did you leave a message? Jason is pretty good about calling you back
Old 02-16-2021   #96
daniels
I ordered a set from him just few weeks ago, and he was very helpful and answered all my questions very promptly and i got the system shipped to me here in Iceland very quickly.
This is the email i used to contact him. Parts@vette2vette.com
I haven't been able to test the system very much, just been able to drive around the block since it's still winter here, but i could definitely feel a big difference just going up the driveway at an angle the car twisted a lot less.
daniels is offline   Reply With Quote
Old 02-16-2021   #97
Corvette95
Corvette95's Avatar
Jason, called me this morning. Of course got voicemail, who answers unknown callers anymore, dang spammers, called him back, got HIS VM. Told him I would call him in the morning. I have an additional part I hope he might can help me with too. So all should be good. I am sure I will be asking some install questions, but if anyone has any installation pics feel free to post or email me a corvette95@gmail.com Thanks!
Old 02-17-2021   #98
Young1
Young1's Avatar
Safety Avisory
I installed one late last summer. I am very pleased. Yes as some noted it does stiffen the ride. Observe very careful with the front bracket installation your brake line bundle on the driver side and fuel line on the passenger side. There is the very dangerous possibility of a rub on the bracket edge. The fuel line i flexed and bent for clearance. The brake lines I isolated with thick pieces of plastic drilled for zip ties. This personal attention to detail sincerely avoided a catastrophe.
Steve Young
Second Owner
SOLD
SOLD
Old 02-17-2021   #99
Have not noticed that kind of potential interference on mine. I?ll need to look for that next time. Planning on changing out the fuel filter. Mine is a 92, not sure if that makes a difference.
