Old 01-28-2021   #601
Roadster
Roadster's Avatar
Default Re: TB removal and then some!!!
More today....still a lot more to do... grease and crud everywhere....
Preliminary cleaning done...a little at a time....20210128_152218.jpg20210128_152721.jpg20210128_154447.jpg20210128_154827.jpg20210128_162718.jpg
Sent from my SM-G981U using ZR-1 Net Registry mobile app
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 01-29-2021   #602
Roadster
Roadster's Avatar
Sometimes the little things are very rewarding....I cleaned and painted the LS front wheel liners a few months ago and although I'm not ready to install yet...figured it would be better to have them together with the correct bolts and u-nuts...as I didn't tag everything....so using the RS as my guide...makes putting what goes where very easy...plus having the FSM....the pics...[emoji16]
Pic #2...Quite a difference from what I started with...
Pic #3...Although not 100% perfect...very acceptable to go back on the 94....can't wait...but still more to do....
Pic #4...Even though I have extra hardware...the RS still not totally disassembled as of yet...makes the LS a breeze to assemble....20210129_184015.jpg20210129_184019.jpg20210129_184029.jpg20210129_144922.jpg
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 01-29-2021   #603
HAWAIIZR-1's Avatar
Nice work as usual Tom! Keep it up; you?re doing a great restoration job!! [emoji1303]🤙🏼
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 01-30-2021   #604
Roadster
Roadster's Avatar
Thanks Craig....little by little.....no light at the end of the tunnel yet....
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 01-30-2021   #605
HAWAIIZR-1's Avatar
You?re welcome Tom! I know the feeling from working on my 90 that came from the Midwest and everything I touched needed work. My 95 from Cali is clean as a whistle. As long as your....?and then some? doesn?t end up with as many posts as the ?two word game? you?re good! 🤣 Take care and best wishes always!! 🤙🏼
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
Old 02-04-2021   #606
Roadster
Roadster's Avatar
Disassembly continues as the RS wheel well liners are now removed....greater access on this side to clean the frame with all of the debris in there...and also check and tighten any connections....if needed....[emoji16]
Pic #1...front RS back part of liner...years of dirt and grime...
Pic #2...definitely some cleanup needed here...
Pic #3...easy access for sure...
Pic #4...time to check all connections and tighten up what needs to be tighten....
Pic #5...backside of panel should be an easy cleanup...20210204_165244.jpg20210204_170859.jpg20210204_170916.jpg20210204_171510.jpg20210204_171830.jpg
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 02-05-2021   #607
Roadster
Roadster's Avatar
Finished the first real stripping and cleaning of the RS wheel well liners..and getting ready for paint.....interesting to note that since the ZR-1 has a wider stance from the front doors back...it really starts with the front rear wheel liner which is ZR-1 specific....having 2 part #'s on the back...and also date produced....20210205_152637.jpg20210205_152849.jpg20210205_152642.jpg20210205_153002.jpg
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 02-06-2021   #608
Roadster
Roadster's Avatar
Does anyone have an idea where to purchase this hose that attaches to the HVAC fan housing....it is part # GEA22....it is shown in the FSM... but no description....tried to check it out and found that it might be a drain hose...but idk...[emoji848]
Thanks for any info....[emoji16]20210206_161736.jpg20210206_154814.jpg20210206_154613.jpg
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 02-06-2021   #609
Roadster
Roadster's Avatar
More progress today.....side frame rail will not need paint like LS did....but top of frame at engine will...paint flaking off in that area... taking apart and cleaning all connectors and relay housings...
Still more to do....
Pic #1...dirt...grease and grime everywhere....major cleaning ahead...
Pic #2...finally got a pic of the Birmal head part #...
Pic #3...decent cleaning to begin with...time consuming for sure...but when it's done...it's done....20210206_124306.jpg20210206_152049.jpg20210206_155526.jpg
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 02-15-2021   #610
Roadster
Roadster's Avatar
So today I decide to take a break from cleaning and take apart the two belt tensioners....following the instructions from mgbrv8....the newer Dayco unit came apart fairly easy...I just need the correct tools to remove the spring and take apart the rest of the original tensioner...
Also followed recommendation from secondchance about the replacement metal pulley...just in case...
So I do an unscientific test...as I am no scientist by any stretch and find that the original pulley is probably on its way out.....due to the excessive free spin and the noise I am hearing when spinning...sounding like the bearing is shot...
So here are a few videos and some pics....all 3 pulleys have a looser fit on the original shaft ...and a much tighter fit on the parts replacement stud....although when tighten on the original stud...there is no play...
Cannot post video here...will do in the FB Group...
Pic #1...taking apart the parts replacement pulley...
Pic #2...need to remove this spring...
Pic #3...original pulley on the left...replacement on the right...both bolts have markings of 32 on them and are the exact same size...
Pic #4...metal pulley recommended by secondchance....20210215_151534.jpg20210215_151618.jpg20210215_155505.jpg20210215_163212.jpg
1974 LS4 454 Vert
1974 L-82 355 Vert.
