Old 01-20-2021   #591
Default Re: TB removal and then some!!!
Applying indirect heat to the aluminum t-stat housing, directing flame downward & away from the bolt head, will expand the aluminum to loosen the bolt "set". Then, when using impact, alternately turn L & R will be more effective than only loosening.
Old 01-20-2021   #592
Roadster
Roadster's Avatar
Will keep that in mind for the future....thanks...
Sent from my SM-G981U using ZR-1 Net Registry mobile app
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 01-20-2021   #593
Roadster
Roadster's Avatar
Front RS head cleaned....
Cleaned and taped all sensor plugs ...ready for install...
First cleaning of oil filter housing....
Won't even need a repaint....20210120_155306.jpg20210120_155227.jpg20210120_170416.jpg20210120_170433.jpg
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 01-20-2021   #594
Tom,
Just a suggestion. You might consider replacing low oil pressure sensor while you have the housing off. If the sensor is old, it might fail and leak oil through the connector and leave an oily mess. Once filter housing is installed, it?s real pain to replace.
Old 01-21-2021   #595
Roadster
Roadster's Avatar
Tom,
Thanks Yung.....I will replace it....good suggestion.....rather do it now than later....
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 01-21-2021   #596
Roadster
Roadster's Avatar
Second cleaning today with oil filter and all sensors removed...very satisfied with the results....
Also part #'s and and an interesting marking and another set of #'s stamped on the housing....[emoji16][emoji16]20210121_151409.jpg20210121_151426.jpg20210121_151436.jpg20210121_151445.jpg20210121_151456.jpg
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 01-21-2021   #597
With all this painstaking cleaning, is there any type of coating that can be applied to cast aluminum parts to keep oil and grime from getting soaked in? Oil and grime build up cannot be avoided but some coating that will make it easier to rinse off?
Old 01-21-2021   #598
dredgeguy
dredgeguy's Avatar
Gibbs? It works on my polished engine.
Charlie
__________
Dredgeguy
Dana 4:10 gears
Polished LT5 by Haibeck
Old 01-21-2021   #599
That?s on polished aluminum. Anything on cast aluminum?
Old 01-26-2021   #600
Roadster
Roadster's Avatar
Between the Groups keeping me occupied....took sometime to get another part cleaned up....
the before....and the after...20210126_200613.jpg20210126_205713.jpg20210126_205723.jpg
1974 LS4 454 Vert
1974 L-82 355 Vert.
