12-08-2020 | #1 |
So... this was in my oil drain pan...
https://www.zr1.net/forum/picture.ph...pictureid=4547
pretty sure it wasn't there before I drained the oil
12-08-2020 | #2 |
Re: So... this was in my oil drain pan...
Right before I changed the oil I noticed the oil pressure was a bit low at idle and the oil temp was a bit higher than usual. I have a bad feeling this is an oil control plug of some sorts but I'm not having much luck IDing it in the FSM. Anyone have a guess on where this came from?
12-08-2020 | #3 |
looks like one of the crankshaft oil gallery plugs
12-08-2020 | #4 |
I agree with Phil. Ties in with your oil pressure observation.
12-08-2020 | #5 |
I found the crank diagram in the FSM, looks like there are 4 plugs in the crankshaft. Is this doable from the bottom by removing the oil pan? Looks like it might be.
12-08-2020 | #6 |
I was just talking to Petey about it. Looks like I'll be ordering a plug and a oil pan gasket from you Jerry
12-08-2020 | #7 |
Make sure you install that with Red Loctite and if you can access any of the others, remove them and Loctite them, too.
I've never heard of one of those coming out and, man, with that missing, I'll bet the oil pressure was low. Interesting that something 5.25-in in diameter would fit though the drain plug hole, but then, I guess I don't remember how large it was.
12-08-2020 | #8 | |
12-08-2020 | #9 |
The front crankshaft throw has a 1/4" npt pipe plug on the forward side and a 3/8" npt plug on the aft side. The remaining 3 throws have 1/4" npt plug on both fore and aft sides. I use hardened steel plugs from the hydraulic supply store. Stay away from the soft plugs you find the local hardware store.
12-08-2020 | #10 |
All plugs are easy to get at once the pan is dropped. While in their might check to make sure the press in plugs are still fully seated. Very lucky the plug came out through the drain hole.
