View Poll Results: Have you ever hit the rev limiter?
YES 147 67.12%
NO 72 32.88%
Voters: 219. You may not vote on this poll
Old 10-02-2020   #131
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
Default Re: Poll: Who has ever hit the rev limiter?
I treasure my car.
I baby the car.
I LOVE my ZR-1!
That said; If you are not, on occasion,bumping into the rev-limiter, then either let someone else drive it if you really cannot bring yourself to do it and witness that the sky will not fall.
OR
Play a little more aggressively with it each time until you do.
Few things in life are as much FUN as DRIVING a C-4 ZR-1.
Any car revs to 5,000.
6,000 still quite a few.
7,000 not many
Aim for 7,500 by holding off until you see the needle pass through 7,000.
At the rate age is slowing me down, I may have to soon start the shift at 6,000 to hit 7,500
When young, I left on the last yellow light.
Today I could almost start one second after the stage light glows.
Ahhhh, the golden years!!!!!!!!!!!!!!!!!
ENJOY IT WHILE YOU CAN!
Go for 7,500!!!
Marty
Old 10-03-2020   #132
richarde
ZR-1 tachometers are notoriously inaccurate due to the IC within the instrument panel cracking and changing resistance due to age, heat and vibration. Batee.com sell a 90-96 Tach Fix 8000rpm kit for remedying this problem. In order to verify the accuracy of the tach, plug in a Tech 1 or ALDLDroid or similar.
Richard
1990, numbers 1821 and 2391
1821 - owned since Nov 2002, charcoal / Gray, Stainless headers, B&B system, 4.10's
2391 - owned since Jan 2019, Black / Black, have completed restoration. Jeal headers, Corsa system, 4.10's, Aluminum flywheel with Carolina clutch.
richarde is offline   Reply With Quote
Old 10-17-2020   #133
Zman
I just hit the Rev Limiter for the first time yesterday. I hit it on a car that had the Tach corrected recently after being told it was reading high. I had the same reading corrected on another car. My guess would be that most Tachs read high. I see 7000-7500 occasionally and have only hit the limiter (once). Hitting the limiter for the first time took all the fun out of it, immediately! If the factory rev limiter is set at 7070 RPMS +/- and I can bump 7500 on a stock 90 without hitting the limiter then I must be reading high on that car also. Just my observations on the matter.
Zman is offline   Reply With Quote
Old 10-19-2020   #134
After I finished calibrating the tach and doing my "510" porting (& Marc Haibeck tuning), I'd hit the rev limiter in 3rd gear about 100 yards BEFORE crossing the 1/4 mile trap. Marc Haibeck had to bump my limiter to 7500 to solve the "problem". I don't hit the rev limiter very often now tho. (I'm good for 121 mph in the traps now, in 3rd gear.
You can see from the 3.45 gear chart where the (7100 rpm) rev limiter would be a hindrance when trap speed of 121 in 3rd gear was in play... Oh! And if you haven't tried the "510" package, you don't know what your missing!!!
Edit: Update: Nearly 1/3 of Z owners have never "let the BEAST out of the cave"! Shame on you!
File Type: jpg ZR-1 ZF6 MPH 345 vs 410 gear ratio-Haibeck - Copy.jpg (117.9 KB, 35 views)
Old 10-23-2020   #135
mcich7781
mcich7781's Avatar
Hit the limiter on the back straight at the Corvette Museum Motorsports Track. Then I had to slam on the binders to turn. It was glorious!
Sent from my SM-G955U using ZR-1 Net Registry mobile app
mcich7781 is offline   Reply With Quote
Old 11-05-2020   #136
EvanZR1
EvanZR1's Avatar
If you've never hit the rev limiter, you're not driving it hard enough!
Having said that, once I put a Raptor shift light in mine, I never hit the rev limiter anymore and I run my car to the shift light every time I drive it. My rev limiter is 7400, and my shift light is set at 7300. The shift light is in the AC vent pointed right at my eye and as soon as it lights, it's an instant reaction to shift (don't actively think about it, it's muscle memory and subconscious reaction). I've spend a LOT of money on this car, and the shift light was the best mod I did to it.
Old 11-05-2020   #137
BigJohn
BigJohn's Avatar
Why, the power drops off before you hit the limiter.
Old 11-05-2020   #138
rush91
What is the rev limit on a Z? Honestly, I've never noticed on a hard run. I know I've hit it because the engine is saying that's all I got, time to shift.....But never been looking at the tach at time of shift to see exactly.
Old 11-05-2020   #139
EvanZR1
EvanZR1's Avatar
Guess I should have clarified, I'm running a 391 with stage 2 cams. The power does NOT drop off.
Old 11-05-2020   #140
BigJohn
BigJohn's Avatar
Cool is it a stroked engine?
