![]() Join Date: Mar 2018
Once while power shifting from 1st to 2nd I slipped off the clutch pedal and missed the gear causing that awful grinding noise.
Is there any need for worrying, or is the ZF6 trans heavy duty enough to withstand the occational miss? That sound is like a rock crusher chewing away on those big rocks at the crushing plant. Luckily for me several buddies was watching when it happened...lol. Sent from my SM-G955F using ZR-1 Net Registry mobile app
Roy Martin 1994 ZR-1 #112 Admiral Blue/Black Dana 4:10 Aluminum flywheel Corsa exhaust Watson headers Haibeck chip 470 HP/399 RWHP 1991 ZR-1 #400 White/Red (SOLD) Dana 4:10 Powder coated engine Haibeck performance chip Borla exhaust |
![]() Join Date: Feb 2012
I have shifted with out the clutch just to get it home.
That was five years ago; still no transmission problems. |
![]() Join Date: Nov 2007
That wont cause an issue at all if your revs are correct. If youre used to driving a stick car you should be able to both up and down shift without grinding... (w/o hydraulic aid)
#4 | |
"If the revs were right"...I guess I was in the 6-7000 rpm range (as usual). I have driven it hard and a lot and never missed a gear before, so that's why I ask if it's bad or not.
I love "using and abusing" it as it's an awesome sports car with an amazing power band.Screenshot_20200903-104112_Gallery.jpg Sent from my SM-G955F using ZR-1 Net Registry mobile app
![]() Join Date: Jan 2010
#7 | |
#8 | |
I just wonder how much wear and tear this grinding may cause... Sent from my SM-G955F using ZR-1 Net Registry mobile app
Here is a video of whats happening when you shift gears. The whole idea of a synchro assembly is to match the speed of the gear shaft with the teeth on the gear itself. So when you "miss a gear", what actually is happening is the shaft and the gears are spinning at different speeds and dont mesh when they should. That causes the grinding sound and since the blocker rings are generally made of brass, they will wear out the fastest. The teeth wear out as well as the cone portion of the blocker ring. I have not opened up a ZF, but many Borg Warners when I was wrenching for a living. We used to rebuild them in house when I worked for Anheuser Busch many years back. The principle is the same.
https://www.youtube.com/watch?v=0Bqs-oHBBQk |
#10 |
The ZF6 is a very stout transmission, but there are limitations.
Speed shifting won't hurt it a lick. Missing a gear while speed shifting, we'll not so much. The 2nd and 3rd gear synchros are fairly delicate. You will know if they need attention. 'Crabs |
