#501 |
![]() Join Date: Mar 2014
Thanks Charlie, hope to see everyone real soon....[emoji16][emoji16]
Sent from my SM-G981U using ZR-1 Net Registry mobile app
#502 |
Hello John....first startup went really well with the 74....but need to address the exhaust issue I am having with the exhaust manifold pipes not going in the configuration that I would like them to be under the car....around the trans......also need to work on the ZR-1 first as I need to put the 74 in that garage slot....so the 74 still is far from finished as the interior is completely out....and still need to change some items in the engine compartment as well...but getting there...thanks for asking....going to sneak in a pic....lol
Intended to do tripower....but then we stayed with the Q-Jet....which is fine...and sold my 68 tripower setup.....then a month later I buy a 67 tripower setup....it's just on my bucket list....so we shall see what happens next year....lol....[emoji16][emoji16] 20200902_130037.jpg Sent from my SM-G981U using ZR-1 Net Registry mobile app
#503 |
![]() Join Date: Sep 2012
Hello Tom,
What media are you using in the Tumber? Thanks, Nelson
WAZOO MEMBER 1993 #124 Ruby 1994 #??? Red/Black 1995 #061 Black/Red 2012 ZR1 Preproduction |
#504 |
Hello Nelson,
Just a smaller unit that I purchased from HF a few years ago. Large enough to do small parts and brackets. It does a decent job. Here is a pic of the unit and the media I prefer to use. The results are good, but it also depends on the time spent in the tumbler. You still need to soak and or wipe the media "dust" off the parts to get ready for paint....etc.....[emoji16][emoji16]JPEG_20200902_224629_2269899710058524322.jpg Sent from my SM-G981U using ZR-1 Net Registry mobile app
Tom 1994 ZR-1 #009 "captured test fleet car" 1974 LS4 454 Vert 1974 L-82 355 Vert. 1982 L83 CFI...now a retired "dd"....Sold WAZOO Member Last edited by Roadster; 09-03-2020 at 12:09 AM. |
#505 |
#506 | |
![]() Join Date: Feb 2012
Hi Tom, You know that driving a big block car gives you a feeling that no other car can. Take your time and enjoy the process! |
#507 | |
#508 |
Since I have items out of the engine compartment.....I would like to remove the thermostat housing and replace the thermostat and clean up the housing itself....but the one heater hose connection is giving me a problem....the other heater hose popped out with no problem....so any advice on how to remove this one is appreciated...and I sprayed some WD40 in there.....I also have 2 new quick connects for replacement...I just don't want to break anything in the process...
Thanks for any info... Pic #1...nice empty space... Pic #2...the one hose on the left...no problem....but that hose circled... Pic #3...two to choose from... Pic #4...bottom view...20200906_115355.jpg20200906_145349.jpg20200906_144133.jpg20200906_144141.jpg Sent from my SM-G981U using ZR-1 Net Registry mobile app
#509 |
Are you also going to install a larger radiator?
#510 |
I have a new radiator......condenser and a totally cleaned out oil cooler to go back in....so I will be ready.....
