Old 08-13-2020   #1
whale
Default A/C control box
Where is the control box located that controls the head for the A/C in a 94/95 model year. It is the unit that has the vacuum lines
whale is offline   Reply With Quote
Old 08-14-2020   #2
Default Re: A/C control box
Above the accelerator pedal it is a black box
Old 08-14-2020   #3
dredgeguy
dredgeguy's Avatar
https://www.youtube.com/watch?v=3jgvX967Q0o
Batee.com is the place to go for any repairs. They did an outstanding job on mine and turned it around in 2 days. Their videos are very helpful.
Charlie
__________
Dredgeguy
Dana 4:10 gears
Polished LT5 by Haibeck
Old 08-14-2020   #4
whale
Thanks Guys
Old 08-15-2020   #5
In "Solutions" ......7th Post under Air Conditioning and Heating
Old 08-16-2020   #6
lfalzarano
Unfortunately buried in the dash!
Old 08-16-2020   #7
Well you can get it out without removing too much..
Old 08-16-2020   #8
Actually pretty easy 👍
Remove 7 (7mm hex heads) screws to drop hush panel (including one nut/keeper on threaded screw by firewall).
Disconnect light and ALDL connector from hush panel.
Remove 4 bolts from lower steel brace.
Everything is then open and available including the several relays or if you want to bypass the Clutch Safety Switch 👍👍
Only takes 5 min for the removal above 👍
Post 292 - Locating Relays Above Drivers Side footwell
Post 293 - Bypassing Clutch Safety Switch
