Old 07-22-2020   #1
Top Toy
Top Toy's Avatar
Default 368 LPE/Haibeck Dyno Results
Time for another good dyno report... Marc just finished a round of upgrades on my new-to-me '95 (replaced my wrecked '93 last year). The car was originally modified to a 368 by Lingenfelter, then breathed on by DRM but never reached its potential. Everything was pretty much sub-optimal. Last recorded dyno before sending the car off to Marc was around 420 RWHP. Pretty mediocre for a 368. Pulled 486 SAE RWHP/405 ft. lbs. torque on the dyno yesterday. That equates to 572 crank HP. Not bad for a 30+ year old design. Kudos to Marc for another outstanding piece of work!
File Type: jpg Derr 95 ZR-1 Dyno Run, 21 July 2020.jpg (107.3 KB, 152 views)
'95 ZR-1, aqua/gray, #167
Old 07-22-2020   #2
Hib Halverson
Default Re: 368 LPE/Haibeck Dyno Results
486 SAE at the tire?
Wow. Impressive. Can beat Haibeck's stuff, that's for sure.
At what RPM were peak power and torque?
Hib Halverson
Technical Writer
former owner 95 VIN 0140
current owner 19 VIN 1878
Old 07-22-2020   #3
Top Toy
Top Toy's Avatar
Peak torque around 5200 RPM and power basically flat from 6500 to 7100 RPM.
Old 07-22-2020   #4
Young1
Young1's Avatar
Wow that is something. Did Mark just computer tune it only? Did he re time the cams?
Steve Young
Second Owner
SOLD
SOLD
Old 07-22-2020   #5
tccrab
tccrab's Avatar
Just a guess, but I'll bet you'll be replacing the rear tires fairly often.......
Enjoy the madness!!!
'Crabs
TomC
'90ZR1 #792
Honorary Pirate
[/B]
Old 07-22-2020   #6
Top Toy
Top Toy's Avatar
Pure stock, just a tune... kidding, of course. Top end porting (including siamesed plenum and injector housings), medium weight (20 lb.) flywheel, cams, headers and 3" exhaust. Well, at least the air filter is stock.😏
Old 07-23-2020   #7
Hib Halverson
When you say "cams"...do you mean stock cams which have had their timing changed or do you mean cams with more aggressive profiles.
If the latter tell us about the cam profiles.
Hib Halverson
Technical Writer
Old 07-23-2020   #8
HAWAIIZR-1's Avatar
Wow Dennis! That?s awesome. Enjoy the new power in your new toy!! [emoji1303]🤙🏼
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 07-23-2020   #9
Top Toy
Top Toy's Avatar
Custom cams Intake 243 deg. duration, 0.449" lift
Exhaust 222 deg. duration, 0.442" lift
Old 07-23-2020   #10
Karl
Karl's Avatar
Are you using the stock clutch with the 20lb flywheel?
1985 L98 Blue On Blue *Sold*
