#91 |
![]() Join Date: Apr 2013
What is the EGR and how do I test it.
Mike Sent from my SM-A205W using Tapatalk |
#92 |
Tried to find info on the EGR in the manual . We could not find info on a EGR .
In the mean time , I changed the oil and will be looking to see why the AC did not come when it worked last time I pulled the plenum to change the FPR . Sent from my SM-A205W using Tapatalk |
#93 | |
H ![]() |
#94 |
Wow . Thanks
Yes I have the FSM , 2 huge red books . Thanks for that very infomative info . Mike Sent from my SM-A205W using Tapatalk |
#95 |
Could you record some video/audio to demonstrate the symptoms you are experiencing?
#96 |
Yes I can . I will do that tomorrow .
Thanks for the help guys Mike Sent from my SM-A205W using Tapatalk |
#97 |
On a related note I just changed plugs on my 94. I bought it awhile ago, but had it in hiding from the wife for longer than normal. I changed plugs for the first time on this car and bought a few different sets. I pulled out some NGK Triex5 I think. I think an older plug of there. It was running fine but I am doing all the maintenance so I know where it is. I replaced these plugs with NGK Iridium plugs and ran fine for a few days then noticed a stumble turning into my driveway. Seems to stumble at times below 2000 rpm, more pronounced at 1000 to 1500. Idle didn't seem quite as smooth but after reading this analysis I might first change plugs, but also check pressure and fpr.
#98 |
I already have LGAFF CD but I can't find the dam thing . I bought that CD even before I got the car . It's here somewhere . Will keep looking or just buy another one . Completely forgot that I had it .
#99 | |
If I had one I could point you i the right direction. H ![]() |
#100 | |
Oh ,, you mean the big read Books ! Yikes ... There a bit of a read indeed . Will figure it out eventually . Not like we can go any where right now so in no rush . Bugs me that I can't find the CD . It will pop up somewhere in the house one day ![]() |
