#11 |
I don't think Marc will have a problem with me posting his response to my inquiry re:134a. Looks a bit less involved than we may have believed. I will swap out the high side switch, just in case, but otherwise...
Hi Dominic, The OE o-rings and switches are compatible with R-134a refrigerant. I have a GM service bulletin advising that. Only three things are needed. 8 oz. of PAG oil, service port adapters for R-134a and the refrigerant. When installing a new compressor, it's a good idea to install a new filter/dryer and a new filter/orifice. Best regards. Marc |
#12 |
![]() Join Date: Aug 2015
Excellent information.. wouldn't expect anything less from Mr. Haibeck!
Sent from my XT1585 using ZR-1 Net Registry mobile app |
#13 | |
![]() Join Date: Nov 2016
Is there any way to tell if the system is already converted? Drier and orifice recommended, I see.
- '90 ZR-1 |
#14 |
![]() Join Date: Apr 2007
Yes. Marc once showed me the GM service bulletin on the subject back in the late '90s when I had my '93 converted. And I think that the fill valves are different for the R-134a than the R-12 but not certain; others know better. --Bob
#15 |
![]() Join Date: Jul 2007
If I recall fill for R134a is maybe 90% of R12
#16 |
![]() Join Date: Apr 2016
The low pressure switch is the same but there is a small screw between the wire terminals that is turned to adjust the low pressure cutoff.
IIRC the low pressure cutoff is 24psi for R-134a and 22psi for R-12 but you need to check the service manual to be sure. |
#17 |
I can tell you that back in the day when I was doing these we only replaced the orifice valve (R134 specific), installed an R134 adapter, evacuated the system, added PAG oil and recharged with R134. A they always worked just fine. I believe any orifice valve you get today will be R134 compatible.
H ![]() |
#18 |
![]() Join Date: Dec 2019
i have just allways screwed on the 134a fittings to the hoses and shot the system, blows ice cold if the system is healthy, never changed nothing
95 admiral blue z(sold)/ / 93 ruby z(sold) 91 steel blue z/95 aqua z haibeck 510, 91 callaway 415 areobody #5 |
#19 |
Old thread..
I replaced my condenser (source of leak), compressor (R134 version), dryer and orifice tube. No pressure switches were changed. I changed the compressor to a NOS unit "while I was in there". Dryer swap good practice. Put in 8 OZ PAG 100. Vacuum for 2 hours. Tight as a drum 24 hours later. System took 1.83 lbs R134A. Blows cold with no issues. Sent from my SM-G950U using ZR-1 Net Registry mobile app |
#20 |
Looks like I need to replace my condenser. I plan to replace it and the dryer/accumulator. The compressor was replaced a few years ago. Can't tell if the system is running on R12 or R134a. I plan to recharge it with R134a. Does 4.5oz of PAG 100 oil (per the manual) sound correct since I'm not doing the compressor?
H ![]() |
