Old 04-25-2020   #31
Default Re: Alternator upgrade
Second chance do you have a post/ write up of the Spal fan install?
Old 04-25-2020   #32
Here you go.
https://www.zr1.net/forum/showthread.php?t=30609
Old 05-15-2020   #33
1LEZ
Did you run the additional 8 gauge wire to the alternator? If so where does the wire terminate? Thanks for the thread! I already got the altenator you recommended
1LEZ is offline   Reply With Quote
Old 05-15-2020   #34
If you are asking Secondchance, he said he did in his first post
Old 05-15-2020   #35
32valvZ
32valvZ's Avatar
Is there any advantage to adding the 8 gauge and 18 gauge for the fan motor without installing a higher amp unit? I have a brand new stock one form Jerrys already installed.... exercise in futility?
Old 05-15-2020   #36
8 ga wire was added between th alternator output to the battery to allow for additional current and 18 ga between the battery to the fan motor. I’m not an electrical engineer and above wiring upgrades were replication of what Marc does when he upped alternator amperage on another WAZOO Z.
Thicker wire alone, may not have much effect.
Old 05-15-2020   #37
Actually the thicker the wire the LESS resistance but the thicker the wire the more current can get pushed through without burning it up.. Heat is generated by the resistance
Old 05-15-2020   #38
[QUOTE=-=Jeff=-;309294]Actually the thicker the wire the LESS resistance but the thicker the wire the more current can get pushed through without burning it up.. Heat is generated by the resistance[/QUOTE
Without alternator with higher output, what effect would larger ga wire have on fan motor?
Old 05-15-2020   #39
More power/current flow to the fans. So the fans would benefit of the larger wiring as there will be less power drop at the fan
Old 05-15-2020   #40
There is your answer 32valvZ.
