Old 03-16-2020   #1
First ZR1
Default Vin number explanation
1G1YZ22J5R5800084
can anyone determine color from the number?
First ZR1 is offline   Reply With Quote
Old 03-16-2020   #2
rush91
Default Re: Vin number explanation
No, I don't believe one can. That VIN looks to be a 1994 red Z with black interior
Old 03-16-2020   #3
QB93Z
QB93Z's Avatar
I agree... 1994 Torch Red with Black Interior
In 1994, GM made 65 Torch Red with Black Interior ZR-1's.
Old 03-16-2020   #4
First ZR1
Great
Thanks!
Old 03-16-2020   #5
mpiecyk
Open your door on the center console you will fine the Service Parts Identification label and you will see your VIN @ the top and all codes pertaining to your car below the VIN.
At the very bottom you will see the Base Coat/Clear Coat Code.
mpiecyk is offline   Reply With Quote
Old 03-16-2020   #6
First ZR1
Awesome..thank you so much!
Old 03-16-2020   #7
Ccmano
Marco Island? This wasn’t yours back in 2017 was it?
H
Old 03-17-2020   #8
First ZR1
Noooooooooooooo!!!
Thank heaven
Old 03-21-2020   #9
TucsonZR1
The VIN tells you its a ZR1, body coupe or convertible and engine. Check the NCRS Manual for a breakdown. If you have a sticker on your center compartment lid it will say the interior and exterior color, if its gone get a build sheet from the Museum.
Old 03-23-2020   #10
Cut n paste this for your file
If the EIGHTH character is an "8", it denotes an L98
