Old 02-08-2020   #1
Default Starts up then begins to run rough and dies
Went to take Z out yesterday for a quick run. It had been out a few days prior w a datalogging session. No problems. I have an Ostrich 2 emulator in the car. New bin, car wouldn’t start. Re-load, same issue. Replace Ostrich w flash prom, car starts using previous bin file but get a Code 41. Flash prom w new bin, car starts but begins to run rough then dies. No code.
I check FP, static w ignition ON jumps to 50psi then drops to 40.
Nothing changed except for loading new bin in Ostrich. With the new build, I’ve been working on refining VE table as well as setting timing now that I don’t have knock. Car has been running great. New bins flash SES w ignition ON as they should. ECM flashes Code 12 when in ALDL as it should.
Also compared the bin files and nothing appears out of whack from one cal to the other. My suspicion is fuel pump.
Discuss.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 02-08-2020   #2
Ccmano
Ccmano's Avatar
Default Re: Starts up then begins to run rough and dies
How long does it run before it goes rough and dies? What does the fuel pressure do it you pull the vacuum line on the regulator?
H
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Old 02-08-2020   #3
H
It’ll run for a few seconds then start to stumble low idle, then die.
Haven’t pulled the vacuum line.
Haven’t checked fuel pressure w motor running. Need 90* elbow to get to rail pressure fitting for that.
I hear pumps with ignition ON.
Old 02-08-2020   #4
Ccmano
Ccmano's Avatar
I would test to eliminate the fuel pumps and filter first. Go from there. Especially since no codes are shown.
H
Old 02-08-2020   #5
Just checked MAP hose and regulator. Looks good.
Old 02-08-2020   #6
32valvZ
32valvZ's Avatar
Any chance the IAC is sticking at some point?
[B]1990 #2815[/B]
Ported Plenum & IH (by Pete)
Haibeck Chip
Rebuilt FPR (by Phil)
FIC Injectors
Watson LT Headers
3" Stainless Works exhaust
Lingenfelter Open Air Lid
Bill B Built Transmission
Shifter & C Beam Plates
[B]SOLD[/B]
Old 02-08-2020   #7
lfalzarano
Fuel pressure regulator?
Lou[COLOR="Red"][B][SIZE="4"][/SIZE][/B][/COLOR]
Old 02-08-2020   #8
K got it. I think the ports on my laptop are going bad. Not downloading bin files properly. Reloaded Ostrich w different cable and motor was fine. Also checked w flashprom and that worked.
Laptop not recognizing USB devices on the ports I am using.
Old 02-08-2020   #9
lfalzarano
Time for a new laptop. Make sure it has solid state drive(s). Don’t chinz out on the memory[emoji512]
Old 02-09-2020   #10
A netbook would be fine. The bin file is 32k.
