Old 12-29-2019   #11
Default Re: Injector Housing Gasket Replacement
And, here is a link to Del City which carries just about all the connectors (with maybe the big one attached to the Digital Ignition System (DIS) module).
And if you go on Ebay......... search for Electrical Connector Tool and you then can replace the connector only without having to splice in (purchase) a PigTail.
Old 12-30-2019   #12
wutanec
Success! Thanks to you guys I have been able to pull the plenum and IH for the first time without too much trouble! I really appreciate those who chimed in
It looks like IH gaskets have been leaking for quite some time as it looked quite nasty down there. I am glad I tackled this one over thess holidays.
I DID run into some trouble however.....When I was pulling the IH on the driver's side, I guess I did not drain enough coolant so some coolant got into the valves, ports to the cam, and starter valley....I was able to clean the valve ports and valley but I am kind of concerned about having coolant mixed with oil...not sure how much got in either...
I am assuming I need to change the oil right away as well?
wutanec is offline   Reply With Quote
Old 12-30-2019   #13
Ccmano
It’s amazing how loose the IH bolts can get. Remove all the spark plugs and spin the engine over with the starter. This will blow out anything in the cylinders. Then change the oil. You should be good after that.
H
Old 01-01-2020   #14
wutanec
Okay I am installing the injectors and fuel rail now. Do I need to install injectors to the rail first? or do they go to the housing first? What is the usual process that works well on ZR1?
Old 01-01-2020   #15
Subfixer
Subfixer's Avatar
I assembled the rails and fuel pressure regulator/fuel transfer tubes first.
I installed the injectors in the rails next, so you can get the clips in.
Then position the rails/injectors over the holes and push them in carefully. Lube the o-rings first.
Be careful not to disturb the fuel transfer tube O-rings.
1992 ZR1 #442, 2 tops, White, White, Haibeck 415, 3.90 gear, Coilovers
2021 Audi RS5, 2.9 V6 Twin Turbo, Auto, Black, Black
2021 Audi Q3, 2.0T, 8 spd Tiptronic, Navarro Blue metallic, Pearl Beige
Subfixer is offline   Reply With Quote
Old 01-01-2020   #16
Ccmano
I mount the injectors to the fuel rail first. Then install the rail to the IH. Then hook up the electrical connectors to the injectors. To me at least the reverse of how lt all came off.
H
