Old 11-20-2019   #1
Default BLM/INT ?
So I'm helping a buddy with his 92.I'm thinking new O2s ?
BLM & INT are low on left bank at operating temp.
BLM L 99, R 132
INT L 100 R 139
Cross-counts are good
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 11-20-2019   #2
oldpro
Default Re: BLM/INT ?
Wow very rich on left side you could switch o 2 s and ck the results before buying a new O 2
oldpro is offline   Reply With Quote
Old 11-20-2019   #3
So could be a bad or leaking injector?
Steve
1990 Red/Red #1473
Old 11-20-2019   #4
oldpro
To ck for s leaky injector put s fuel pressure gauge on the shreader valve at the end of the passenger side fuel rail . Turn on ignition then turn off and see if the pressure holds if you loose pressure right away then you could have a leaky injector
Old 11-21-2019   #5
Thanks my though also, I now what the readings should look like, did not know what it was showing as far as rich or lean on the left bank.
Steve
1990 Red/Red #1473
Old 11-21-2019   #6
BLM L 99, R 132
INT L 100 R 139
Have u checked for any exhaust leaks on the Left side?
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 11-21-2019   #7
No have not, When driving it had a slight roughness when the secondary's opened but cleared up after 5500rpms.
Steve
1990 Red/Red #1473
Old 11-22-2019   #8
Well I see the gang has nailed all the "low hanging fruit". One thing tho, can you get an average voltage readout for the O2s? 400 to 500mV is good. 700s and up indicate rich and 300 and less indicates lean.
Assuming the O2s are verified to be in good operating order, (and generally speaking) IF a BLM reads rich, I'd be thinking of leaking injector(s), maybe. But, if lean, I'd be thinking of measuring the resistance of the individual injectors when they are HOT.
Swapping O2 position is where I'd want to start - see if the errant readings follow the O2.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 11-22-2019   #9
Thanks Paul,
may be a few weeks before I get back to his house, I do have 2 good O2s I changed out of mine years ago when I had Marc do the upgrade package I'll try one of them on the left.
As to voltage readout both range (Stock car) from the high 90s to just over 700 constantly cross counting. On my car I get reading from 80s to 800 but its not stock.
Steve
1990 Red/Red #1473
Old 11-24-2019   #10
Hib Halverson
With block learn and integrator low, the system is obviously pretty rich and, thus, pulling a lot of fuel. That in conjunction with "cross-counts are good" has me thinking an injector problem rather than an O2S problem.
Run the fuel pressure tests in the Service Manual. If those tests pass, then swap the O2Ses. If the problem moves to the other bank, then I'd replace both O2Ses.
If the problem stays on that side, I'd pull the injectors and send them to someone like RC Engineering for cleaning and testing.
Hib Halverson
Technical Writer
former owner 95 VIN 0140
current owner 19 VIN 1878
