Old 11-16-2019   #1
ALLTHECAMS
ALLTHECAMS's Avatar
Default Lowering my Z: wedges vs coilovers
i have a 1991 ZR-1 with 82k miles. When I bought the car 3 years ago it had cheap KYB shocks on it. I found some used FX3 shocks on ebay and put them on the car but I still dont have the actuators. Not sure the system will work either.
Now I want to lower the car but I'm wondering if I should convert to full coilovers or just install the wedges. I've already done the rear bolts to try to level the car. I live in MN so ride quality is somewhat of a concern due to potholes, uneven pavement etc.
I do see the Van Steel single adjustable street kit is on sale...
Thanks
Matt
ALLTHECAMS is offline   Reply With Quote
Old 11-16-2019   #2
FormulaReed
Default Re: Lowering my Z: wedges vs coilovers
Coilovers are great for track cars, but for a street car they kinda suck. Especially if you live in an area that has bad roads. The roads in Seattle are trashed, and my daily driver has coilovers. I regret putting them on every time I drive that car. Much better at the track or autocross, but for street driving they are much worse than stock.
FormulaReed is offline   Reply With Quote
Old 11-16-2019   #3
Karl
Karl's Avatar
I don't know why but coilovers seems to be love it or hate it here.
I am on my 2nd Z and I had DRM coilovers installed on both cars with some type of harness bar that connects to four points.
I remember when I sold my '92 the buyer on the test drive saying how great the car rode and felt compared to leaf springs. And this was from a seasoned C4 owner.
It is a pricey investment compared to the wedges.
Good luck on your decision.
Old 11-16-2019   #4
Pete
Pete's Avatar
What spring rates do you have i have noticed people going with way too stiff spring rates for the street.
Specially rear spring rate.
I have 400 front and 225 rear and its fine.
I see guys going with 450-475 fronts and 275-300 rears which i think are a lil too much for street use.
Does anybody know what stock (1992-1995) spring rates equal to for a coilover spring.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 11-16-2019   #5
TX '90 ZR1
TX '90 ZR1's Avatar
Thanks
Matt
Matt,
I've got some actuators and a couple of control modules. If you decide to stay with the FX3's let me know and I'll see what all I have.
(Left you a note at the "other" place also.
Kenny
1990 #442
Old 11-16-2019   #6
RussMcB
I may be mistaken, but a coil-over set up can feel exactly the same as the stock set up if the spring rates and shock settings are similar. To say coil-overs are not good for the street sounds wrong to me. It seems more likely the spring rates or shocks are to blame, not "coil-overs".
I think the reasons to change to coil overs are,
  1. More options for spring rates
  2. More options for shock valving
  3. Ability to adjust ride height (and corner weights).
  4. High checkbook balances
Old 11-18-2019   #7
ALLTHECAMS
ALLTHECAMS's Avatar
I decided to go with the Van Steel street kit after getting feedback on social media from a Z owner who had them on his car. Hopefully they aren't too stiff. He seemed to like them.
Sent from my XT1710-02 using Tapatalk
Old 11-18-2019   #8
lfalzarano
Be careful of coil over ride height adjustment for street/driveway use.
Old 11-20-2019   #9
Anniv88
Anniv88's Avatar
I put coilovers on my Z and went with the spring rates for the 95 Z.
The car is barley tolerable to drive in the touring setting.
My experience tells me if you have the same spring rates for leaf springs
and coil springs the coil springs are going to be much stiffer.
Anniv88 is offline   Reply With Quote
Old 11-20-2019   #10
RussMcB
Hmm. A spring is a spring. A 500 lb spring takes 500lb to move an inch.
Are the ends of the stock leaf spring further outward than the lower shock mounts? That might mean you'd need a lighter coil spring to achieve the same wheel rate.
Just surmising. I've been happy with my stock suspension so haven't considered or investigated any changes.
