Old 10-14-2019   #491
Roadster
Roadster's Avatar
Default Re: TB removal and then some!!!
Pic #5....the new unit...
Pic #6...with oil cooler...
Pic #7...LS of oil cooler lines up with bracket holes on the new unit...
Pic #8...RS of cooler need to elongate the holes slightly as mentioned above to fit....but again the new unit does have provisions for oil cooler installation....
And thank you again Craig for the comments....very much appreciated....
Sent from my SM-G965U using ZR-1 Net Registry mobile app
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 10-14-2019   #492
Roadster
Roadster's Avatar
Just leaving the radiator shop....not worth the time to get the condenser pressure tested....as he can only put 15 lbs of pressure on the unit...and the condenser has way more pressure pass through it....unless there was obvious staining on it....there probably is no major leak....and if there is a minute leak...he would not be able to determine that....so it looks like I may go with the replacement unit. He also advised against painting the fins on the condenser or oil cooler....as I was also thinking those thoughts myself...[emoji16]
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 10-14-2019   #493
Roadster
Roadster's Avatar
Called a Automotive AC repair shop and they basically said the same thing....just blow some compressed air in the opening...leaning towards using the new unit....but still may attempt to clean the condenser out like I did the oil cooler as per Phil....
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 10-26-2019   #494
Roadster
Roadster's Avatar
Tumble...tumble.....tumble....that's part of what has been going on for the last few days....finally unboxed my tumbler and put it to good use....also been purchasing some radiator cushions the last few weeks....so I'll have what I need when I put the cooling system back together....might have to modify one or two of them using the new A/C condenser...glad to have some extras....[emoji16][emoji16]
Pic #1...magnet making it easy to fish those parts out...
Pic #2...may as well do some ZR-1 hardware as well....since I'm also doing the 74 hardware....
Pic #3....some hardware for the 74....to be polished in the next stage...
Pic #4...first cleaning....
Pic #5...years of grime...
Pic #6...so far.....looking good....cleaned and protected for future use...20191026_125640.jpg20191026_124855.jpg20191026_124809.jpg20191025_220907.jpg20191025_225428.jpg20191026_132628.jpg
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 09-01-2020   #495
Roadster
Roadster's Avatar
Well its been 2 years and going on 4 months since the 94 last ran. Since the 74 is now home and I'm in the process of getting the garage and basement reorganized, it is time to get ready to get the 94 running again.
Radiator, oil cooler and condenser are still out of the engine compartment. Still would like to do some additional cleaning before reinstalling everything. Also giving some thought to changing out the thermostat, since I have better access. Have to check my records and see if it was changed before.
Also have Jerry's new oil cooler lines to install. And maybe thinking about back flushing the evaporator, maybe not.
So when you have time to do things, you do the little things to, such as cleaning up the clamp that secures the AC line along the front rail.
The cable or hose clamp had some corrosion inside of the rubber part and on the metal part as well. Some soaking, sanding and paint and rubber dressing makes them look good again.
This particular clamp is hard to find, it appears that most of the parts houses don't stock this particular part # and some of the other places require a business account to purchase. They do make them in a number of sizes and I'm sure for those that need replacing, a close replacement can be used.
Looking to have the Z running sometime this month. I do miss driving the 94, but with so much going on with my other projects, the time has and is flying by....[emoji16][emoji16]
Pic #1 after cleaning
Pic #2 before paint and rubber dressing
Pic #3 clamp painted and hanging out to dry
Pic #4 rubber dressing applied
Pic #5 back together and ready for service
Pic #6 just another view20200901_132931.jpg20200901_132948.jpg20200901_133827.jpg20200901_134302.jpg20200901_155102.jpg20200901_155106.jpg
Sent from my SM-G981U using ZR-1 Net Registry mobile app
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 09-01-2020   #496
Jagdpanzer
Jagdpanzer's Avatar
Glad your back on the board Tom and sharing some attention on the 94.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 09-01-2020   #497
HAWAIIZR-1's Avatar
You always do nice, detailed work Tom!!
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 09-02-2020   #498
Roadster
Roadster's Avatar
Thanks Phil, the 94 has been covered in the garage way too long. At least its clean....lol. I will be extremely happy to have the LT5 singing once again....
Appreciate the compliment Craig, I try...lol may not get every little detail, but do what I can get to.....
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 09-02-2020   #499
dredgeguy
dredgeguy's Avatar
Good to see you back Tom! As always, great job
Charlie
__________
Dredgeguy
Dana 4:10 gears
Polished LT5 by Haibeck
Old 09-02-2020   #500
BigJohn
BigJohn's Avatar
How is the 74 running now that it is finished?
