Go Back   ZR-1 Net Registry Forums > C4 ZR-1 > C4 ZR-1 NCRS Topics
Old 07-29-2019   #1
SitkaSam
SitkaSam's Avatar
Default 93 Gas cap
Does anybody have the correct number for the gas cap for NCRS judging?
I think mine had a locking cap as the keys are here but has been replaced. Not sure if this one is correct?
Thanks so much
SitkaSam is offline   Reply With Quote
Old 07-30-2019   #2
jrd1990zr1
jrd1990zr1's Avatar
Default Re: 93 Gas cap
I believe the OEM gas caps were non-locking. They are also date coded if you are doing the NCRS process. Date code is embossed on the underside of the cap and is normally checked by the judges.
1968 convertible Lemans Blue,
1986 coupe Medium Blue NCRS Top Flight (sold),
1990 ZR1 #2529 Red NCRS Regional and National Top Flight (sold),
1990 ZR1 #2124 Charcoal Metallic NCRS Top Flight 2010 & 2018,
2003 Anniversary Red Convertible (sold)
Old 07-30-2019   #3
Joelbbvette
Correct, mine got hit for being a replacement date for a point or two. No biggie.
Joelbbvette is offline   Reply With Quote
Old 07-31-2019   #4
TX '90 ZR1
TX '90 ZR1's Avatar
OK guys.
You have me all worried now about having the correct date on my gas cap!!
Where is the date exactly? Mine has numbers 2(space)269 on the bottom side of the threaded part. Does this tell us anything??
Kenny
1990 #442
Old 07-31-2019   #5
jrd1990zr1
jrd1990zr1's Avatar
Originally Posted by TX '90 ZR1 View Post
OK guys.
The date is in small raised numbers on the treaded side of the cap. On the end which goes in the tank first. First number is the year followed by a space then followed by the julian day of the year. So your cap if it is a "slant" cap and looks like the one in my post above, appears to be dated 1992, the 269th day of the year. The cap on my 1990 is 0 180, which is a 1990, 180th day of the calendar year which follows the build date of my car.
From a judging perspective (since yourcar is a MY 1990) the most I can see you could lose is 20% of the originality points assocated with the cap, due to the cap having the wrong date code. Condition points could also be taken if the cap is damaged or aged (discolored).
Sorry for being long winded.
Old 07-31-2019   #6
TX '90 ZR1
TX '90 ZR1's Avatar
Thanks for the reply. I appreciate the thorough explanation.
My cap does look exactly like the one in the pic.
Looks like I will be putting a correct date coded fuel cap on my list of things to keep an eye out for.
Thanks again,
Kenny
1990 #442
Old 08-01-2019   #7
Joelbbvette
Kenny,
Don't let the gas cap stop you as long as it looks correct, then it is a GM replacement part. Small deduct but nothing huge.
Joel
Old 08-01-2019   #8
TX '90 ZR1
TX '90 ZR1's Avatar
Originally Posted by Joelbbvette View Post
Kenny,
Joel
Hey Joel,
Not letting these "little things" stop anything, but it is amazing how many of the "little things" I have been able to locate just by keeping my eyes open.
Looks like you did great with your car. Congratulations!!
Kenny
1990 #442
Old 08-01-2019   #9
jrd1990zr1
jrd1990zr1's Avatar
Hey Joel,
As mentioned above the date code alone shouldn't be more than a 1 point deduct.
Old 08-13-2019   #10
SitkaSam
SitkaSam's Avatar
Thanks for all the info...but.....
My 93ZR1 has 8,000 miles on her and the original owner was anal about his Z, keeping everything from the key punch-outs and every document that came the car. He had two gas cap keys for locking cap, the window sticker has "Delco locking ll" Am wondering of that was an option?
I would appreciate any technical information if this was an option. The NCRS Judging manual says absolutely nothing about a locking cap, only that it is peaked and "Caution Remove slowly as spray may cause injury". The locking cap has no date, red center and made in USA
Thanks....another Z mystery?
