Old 07-01-2019   #41
Tripler
Tripler's Avatar
Default Re: Ruff Idle ,Huge Loss of Power
https://www.youtube.com/watch?v=EDt5IYIB5k8
Tripler is offline   Reply With Quote
Old 07-01-2019   #42
Tripler
Tripler's Avatar
Bit off topic but thought you might enjoy this .
Kid puts me to shame with his mechanical skills and he can get to the tight spots easy lol . One lucky boy to be working on a ZR-1 so young .
https://www.youtube.com/watch?v=pXWg84w98l4
Old 07-01-2019   #43
Ccmano
Cool Kid! That’s how you get them started early. I wonder if his dad or grand dad are members here?
H
Old 07-05-2019   #44
cp1joel
Hi Mike,
How did you go sorting your Ruff Idle, loss of power issue?
Have experienced this multiple times.
Cheers
cp1joel is offline   Reply With Quote
Old 07-05-2019   #45
Tripler
Tripler's Avatar
Originally Posted by cp1joel View Post
Hi Mike,
Cheers
Hey . How's things .
Just got off the phone with Marc Haibeck and ordered the DVD plenum pull video and the throttle body bypass tube . Since I am draining the car by 2 litres as per Marc's instructions , I may as well install the bypass .
Also when talking to Marc and I told him what the car was doing he told me I did not have to tell him anymore info as it is definitely the FPR .
Been in contact with Phil also and once I get the FPR out I will mail it to Phil to be modded .
Looks like this will be a month or 2 process but the beast will run again .
Also have to call Jerry's Gaskets and order new o rings for the injectors .
FPR .
Mike
Old 07-05-2019   #46
Tripler
Tripler's Avatar
Hi Mike,
Cheers
So you have also had this issue ? Have you replaced the FPR ? Did you giVe Marc Haibeck a call or hit up the issue on this forum ? Just curious how you got it sorted and what where the issues if not the FPR .
Thanks
Mike
Old 07-17-2019   #47
Tripler
Tripler's Avatar
If the fuel pressure regulator is bad, with raw fuel being pulled into the plenum from a ruptured membrane, checking the fuel pressure is largely irrelevant. Assuming the fuel pumps are good you will simply see maximum pressure ~50psi.
H
hooked up the pressure gauge
and it stays at 48 psi . I did not start the engine ,only with key on .
Thanks
Mike .
Old 07-17-2019   #48
Tripler
Tripler's Avatar
There is a Schrader valve at the front of the passenger side fuel rail. Attach a pressure gauge there for static pressure tests, (AND (FYI) if you purchase an extension hose, you can do impromptu dynamic tests by taping the pressure gauge to the windshield and going for a drive (not necessarily applicable to this particular problem))
Tight fit but I was able to attach a fuel pressure gauge . With key on , pressure held at 48 psi for 3 minutes or so .
Thanks
Mike
Old 07-24-2019   #49
Tripler
Tripler's Avatar
Added some lighting to do the operation . Be going in next week .
Plenum, Injectors , FPR removal
Sent from my ASUS_X00PD using Tapatalk
Old 08-15-2019   #50
Tripler
Tripler's Avatar
Found an interesting way to drain the plenum , unless some of you guys already have done this . I hooked a small hose to the glycol fluid tube at the lowest point of the plenum towards the firewall on the right side . Then the fluid will automatically syphon out into a lower point , in this case , a measured dish for 2 litres marked so I knew how much I removed . Obviously radiator fill cap is removed or open. You will hear the fluid syphon out and just watch your fill dish level and pinch off the the hose or remove it and voila, no fluid in the plenum .
I tried using a mechanical way to suck out the glycol , but nothing was happening so then tried the hose trick and that worked great .
