Go Back   ZR-1 Net Registry Forums > C4 ZR-1 > C4 NCRS for ZR-1s
Old 10-29-2018   #21
Default Re: Inside Rear Tail Lights Red and Orange
Sure PM with tour info.. do you take PayPal?
Old 02-03-2019   #22
I don’t see these working right with just the lenses and not the divider to keep the Amber from shining when the brake light was used. These EURO setups also have bulb sockets that are exclusive to the EURO housings,I have the part numbers somewhere for the bulb sockets.
Old 02-21-2019   #23
Corvettes White
Originally Posted by precast1 View Post
Ok will that pass judging because I believe the car came that way and would the euro lights show on the build sheet?
He should for an export car.
Old 02-23-2019   #24
tnova
Had a similar issue with my brand "P" track car. A solution is to use the Euro amber lens without the divider with red LED bulbs. There will be bleed over without the divider but the increased intensity should suffice. Red LED bulbs are readily available. Search for AMAZENAR Red LED bulbs using the common bulb identifier. I got mine on Amazon. The red LED bulb overpowers the color of the amber lens.
Tony, TNova
tnova is offline   Reply With Quote
