10-17-2018 | #1 |
Aluminum flywheel.... new clutch?
Thinking about swapping out to an aluminum flywheel, do you have to or need to get a new clutch when swapping flywheel? Car a 92' has 20k miles so I'm assuming clutch wear is minimal.
Looking at a fidanza 198551 |
10-17-2018 | #2 |
Re: Aluminum flywheel.... new clutch?
FYI: converting from a dual mass flywheel will result in transmission rattle which is loudest when in neutral with clutch engaged.
The Fidanza FW weighs in at 13-14 lbs Jerrys Gaskets has custom manufactured aluminum FW’s at both 18 & 22 lbs. read more about applications & benefits; http://www.jerrysgaskets.com/flywhee...let-90-95-0b3/ http://www.jerrysgaskets.com/flywhee...let-90-95-0b1/ Sent from my iPhone using ZR-1 Net Registry
Jerry Downey JERRYS LT5 GASKETS & PARTS http://www.jerrysgaskets.com 1994 ZR-1, Black/Black, Lingenfelter Aerobody, 416cu in, 3.91 gears, coil-over susp, Brembo brakes, etc. 2016 Black-Red, 3LT-Z51 Auto 8-speed. Last edited by A26B; 10-17-2018 at 09:17 PM. |
10-17-2018 | #3 |
My fidanza sounds like a sawz-all at times up until 2,500 RPM......All though the motor will spin up much faster .....The gear rattle in neutral really doesn't bother me......I hear some have used a sprung hub disc to mitigate the noise.....
No,stock clutch can be used....I did and I was at 46 k... |
10-17-2018 | #4 | |
10-17-2018 | #5 |
I have Fidanzas in three cars. I'd follow Jerry's suggestions.
If you choose Fidanza, I would replace the clutch disk and make sure it's a spring hub and minimum thickness. Be sure to clean the frictions surface on the flywheel. Ted |
10-17-2018 | #6 |
Recommendations on a disc/sprung hub?
10-17-2018 | #7 |
I think I have a Fidanza for sale. I might have sold it.
10-17-2018 | #8 |
10-17-2018 | #9 |
10-17-2018 | #10 |
