#41 | |
![]() Join Date: Aug 2015
Sent from my XT1585 using ZR-1 Net Registry mobile app |
#42 |
I have a set of vacuum Actuators. PM sent.
H ![]() Last edited by Ccmano; 08-06-2018 at 09:20 AM. |
#43 |
#44 | |
![]() Join Date: May 2010
#45 | |
#46 |
Got the numbers back yesterday on flow test of assembled and ported Plenum and Injector Housings. This was with a Superflo 1020.. we checked cylinders 4 & 5..
Cylinder 4 Primary 174 cfm Cylinder 4 Secondary 178 cfm Cylinder 5 Primary 173 cfm Cylinder 5 Secondary 176 cfm Total flow both ports open Cylinder 4 - 352 cfm Cylinder 5 - 349 cfm Trouble with removal of one torx screw on one TB blade. Got it out, but will need to retap and possibly use slightly larger screw. For those who decide to tear down their TB for porting or as in my case, powder coating, be aware of the spot welds on the ends of the screws after they are installed! Locktite would have been a much better method than this! Pulling brake booster to remove last two driver side cam cover bolts so I can get everything out to powder coat next week.. Sent from my XT1585 using ZR-1 Net Registry mobile app |
#47 |
Well pulling the brake booster was a major PITA! The lower two lock nuts are "relatively" easy to remove, but the upper two require dropping the steering column and removal of the cruise control vacuum can, ECM, etc.. not a job for the faint of heart for sure.. passenger side is simple, just remove the evaporator coil cover near the firewall.
I used an impact to remove the Torx 40 cam cover bolts. This was easy, none of the bolts gave me any crap. Had to remove a few with a long handle 3/8" flex head rachet. I bought a set of "stubby" Torx 3/8" & 1/4" drives as well. Cams look very good. Very light polish on the lobes. Prepping everything for powder coat..[ATTACH][ATTACH][ATTACH][ATTACH][ATTACH][ATTACH] Sent from my XT1585 using ZR-1 Net Registry mobile app Last edited by jss06c6; 08-19-2018 at 08:40 PM. |
#48 |
![]() Join Date: Jan 2010
Helpful hint:
Take the driver's seat out, 4 nuts and a couple electrical connectors. Makes working under the dash MUCH easier! Besides, no telling what you'll find there... |
#49 | |
Everything headed to powder coat this week! Sent from my XT1585 using ZR-1 Net Registry mobile app Last edited by jss06c6; 08-19-2018 at 08:45 PM. |
#50 | |
H ![]() |
