Looking for members who have knowledge of these scanning tools. If you have used ether of these would you post the pros and cons of them. I do not know much about ether one. I am thinking I should get the Tech 2. From what I have read it can be used on the 92 to 2010 vetts' I am having a problem with a 93 ZR1. Not getting the 405 HP and not throwing a engine DTC code. I have no vacuum leaks so it must be electrical. I repaired a vacuum leak under the plenum and while under there I made sure the actuators were working.
Thanks for your input. |
![]() Join Date: Jul 2016
Personally, i would use a Tech 2. Btw, a possible mechanical cause of your problem is the throttle body. Marc H found mine did not open fully, even with the pedal to the floor. Had him recondition the TB, problem solved. Apparently, this isn’t uncommon as the cars get older.
#3 | |
I moved to St. Louis this summer Andy need to update my profile. I shipped the car to Marc because it needed other service, then took Amtrak to Chicago and drove it back. Other members have just shipped the TB to him.
![]() Join Date: Jun 2005
There'd be little advantage to a T2 vs a T1 for working on a ZR1 other than a screen which will display more lines of data.
Some T2s, especially the Chinese knock-offs, may not have the proper software so, if you buy at T2, make sure the software package which comes with it supports OBD as well as OBDII systems.
#6 | |
Thanks again Ellis |
