Thread Tools | Display Modes |
#131 | |
![]() Join Date: May 2007
I have traveled a lot of miles on road trips and have helped many other ZR-1 owners with repairs at events and in parking lots. Over the years, I have compiled a collection of tools, parts and supplies that I keep in my ZR-1 all the time. In order to carry all this stuff, I remove the "liner" and tire jack (moved to the spare tire) from the storage compartment behind the passenger seat. I have 1994/1995 Z's, the arrangement in the earlier years storage compartment may be different. The only things that I don't carry in the compartment is a 12-volt tire inflator and the jumper cables. When you have a dead battery you cannot open the rear hatch, and with a rear hatch full of luggage, you can not get to the jumper cables. I learned this the hard way in Canada on the way to Alaska. My theory on the parts I carry is that they can be replaced in a parking lot but may not be available locally without a delay for shipping the part from a remote supplier. Parts and Supplies alternator serpentine belt fuel pump fuel pump cross-over cable idler pulley 24" of 5/16 coolant hose plenum gaskets throttle body gaskets brake fluid dielectric grease gasket sealant hose clamps for fuel lines in gas tank fuses - assorted sizes and amperage Tools 1/4 drive sockets up to 1/2" and 13mm 3/8 drive sockets up to 5/8 and 14mm 1/4 and 3/8 universal joint and assorted extensions 3/8-1/2 drive adapter to use for releasing the belt tensioner SAE and metric allen wrench sets small set of combinations wrenches slip-joint pliers, two sizes cutter pliers, two sizes needle-nose pliers bent tit needle-nose pliers crescent wrenches 9-in-1 screw driver torx bit socket set long shank T-40 torx bit long shank T-25 torx bit siphon pump and tubing compact digital multi-meter assortment of test leads and jumper wires 12-volt electrical probe tool with extended cable special ratchet torx bit tool to remove the MAP Sensor bolts masking tape to cover injector housing ports when plenum is off flash light wire stripper/crimper tool with assorted lugs scissors tire inflator (12-volt, plastic wrapped in spare tire) jumper cables (under passenger seat) 9" block of wood to support the front of the plenum when working on the alternator work gloves zip-lock bags to hold parts removed There are probably some tools that I missed because I made this list from memory. Jim Last edited by ZBrink; 3 Weeks Ago at 12:16 AM. Reason: Spacing edits |
#132 |
![]() Join Date: Apr 2013
Hey Jim . Also add to your list of tools those small car booster's. It's only like 5"x3"x1" or smaller and has enough juice to jump start a car a few times . They also have usb charges built into them . We got ours at Costco but many places now sell them . Its for those times like you said , when you can't get to the booster cables .
#133 |
![]() Join Date: Apr 2007
Jim--
Thanks for the detailed reply to my questions about planning your trips. One would almost think that at some point in your life you had planned for some fairly extensive trips with lots of details to them, perhaps underwater.... Your planning tools and approach will be very helpful to me for future road trips so I do thank you for enlightening me. Maybe I'll plan another road trip kicking off after next year's BG gathering. The week long road trip we just undertook was a piece of cake by comparison to yours but it still required planning over a month or so to line up everything following the Corvette gathering in Ontario organized by Bob Lambe. --Enjoy your well earned rest at home!--Bob
