Old 07-03-2018   #1
Norwegianmopar
Norwegianmopar's Avatar
Default Plugs and wires
What plugs and wires do you guys recommend on the LT5?
Sent from my SM-G955F using ZR-1 Net Registry mobile app
Roy Martin
1994 ZR-1 #112 Admiral Blue/Black
Dana 4:10
Aluminum flywheel
Corsa exhaust
Watson headers
Haibeck chip
470 HP/399 RWHP
1991 ZR-1 #400 White/Red (SOLD)
Dana 4:10
Powder coated engine
Haibeck performance chip
Borla exhaust
Norwegianmopar is offline   Reply With Quote
Old 07-03-2018   #2
Default Re: Plugs and wires
I use to run AC Delco Rapidfire #5 and AC Delco wires - non-logo orange color wires. A few years ago, AC Delco went to platinum tips for Rapidfire plugs. Since I could no longer find original Rapidfire plugs, I went to NGK Iridium plugs and had no issue. I still use AC Delco plug wires. Heat range - that's one of those interesting subject...
Old 07-03-2018   #3
G-Sting
G-Sting's Avatar
I still have the original wires and plugs. But low miles. Runs great.
Jerry's Gaskets sells LT5 wire sets - new, NOS, etc.
One example...
http://www.jerrysgaskets.com/wire-se...lug-90-95-9b2/
'94 ZR1 LT5 - Dark Red Metallic
'79 L82 4-speeds of fun
'96 LT1 Borla, H-pipe, TB, CAI (Sold)
"An adventure is only an inconvenience rightly considered. An inconvenience is only an adventure wrongly considered." -- G.K. Chesterton
G-Sting is offline   Reply With Quote
Old 07-03-2018   #4
Billy Mild
I have a set of used wires from my old LT5. They are all there except 1 wire was replaced an aftermarket one. I will let them go cheap.
Old 07-04-2018   #5
Norwegianmopar
One example...
Thanks for the heads up. Looks like they have a lot of goodies.
Roy Martin
Dana 4:10
Aluminum flywheel
Corsa exhaust
Watson headers
Haibeck chip
470 HP/399 RWHP
Dana 4:10
Borla exhaust
Old 07-04-2018   #6
Following Pete P's recommendation, for 11 years now I've been using the AC Delco 41-602s.
They aren't made of rare earth - just good ol copper. They work as well as the Iridium (Champion) plugs do, but I can buy 4 or 5 of the 41-602s for the cost on ONE of the exotics.
(They) won't last as long some say? Well, at ~ $2/plug vs $9-10+/plug I can afford to replace them every season. And, with the LT5. it is so easy to get to the plugs there's no need to spend big $ for plugs that last 20k+ miles (and suffer those last few k miles with dying plugs). I can put in new plugs every season or two - and also assess how each cylinder's injectors are working while I'm at it.
These plugs in the photo are some 41-602s I pulled out for inspection that have been in service for two seasons (~6k miles). They're practically like new! What do you think?
File Type: jpg AC Delco 41-602s with aprox 2800 miles.jpg (245.8 KB, 44 views)
Old 07-04-2018   #7
Norwegianmopar
This is what Marc Haibeck said:
"We use NGK TR5IX spark plugs. They come with a 1 mm gap. Don't change the 1 mm gap.
The wires almost never cause a problem. You should not replace them unless we have more evidence identifying them as a problem. If you do replace the wires, we use the AC-Delco wires for the LT5. They fit better than any other brand. I can provide a part number if necessary."
Roy Martin
Dana 4:10
Aluminum flywheel
Corsa exhaust
Watson headers
Haibeck chip
470 HP/399 RWHP
Dana 4:10
Borla exhaust
Old 07-04-2018   #8
G-Sting
G-Sting's Avatar
One example...
You're welcome. You might know already (but maybe other new folks here don't know)... but Jerry is a member with a '94 Z -- screen name 'A26B'
All the best in your getting that Z-Viking-Longship into top fighting shape!
Old 07-19-2018   #9
Silverfox1
I have a '95 (#386) w/25k mi & what appears to be original plugs (AC 907s) which looks to be the same as 41-907 in owner's manual. Manual says gap .050" & plug I took out (#3) was just that. Car runs good & smooth, but from what I gather, plugs s/b changed. Maybe it will run even better. Easy & cheap enough.
I see reference to 41-602s. Is that same as 907? Car is not raced, just plain old spirited street driving. My inclination is to go with copper ACs, but i saw 1 reference that Haibeck recommends NGK TR5IX.
Thoughts welcome.
Thx
Silverfox1 is offline   Reply With Quote
Old 07-23-2018   #10
rkreigh
the lt5 has a very efficient combustion chamber and the stocker stuff works great to 700 hp
I've tried all the fancy plugs and wires and stuff and like the
ngk
delco
denso
all work really well and I've dynoed the car and can say there really isn't any difference
I would recommend the delcos and change them more often as it's good to inspect the plugs
last time I pulled $6 water shot out
