Old 06-17-2018   #1
jss06c6
Default R-12 to R-134 conversion
Gents,
About to swap over to R-134. I've got the compressor and accumulator. To be clinically correct, I'll need to swap out the high pressure line to R-134 configuration. Anyone with one in good condition to sell, please send me a PM, otherwise I'll TIG in a new high pressure port.
What about the high and low pressure switches. Are the R-12 switches compatible with R-134 and the higher pressures? If they need to be replaced, are they available?
Thanks!
Steve
Sent from my XT1585 using ZR-1 Net Registry mobile app
Old 06-17-2018   #2
Default Re: R-12 to R-134 conversion
Originally Posted by jss06c6 View Post
Gents,
Thanks!
Steve
If you are going to do it right you should replace the condenser as well as they are different. No the switches are not compatable. I suggest not doing it if you can avoid it as the R134 system conversion won't be as cooler as the R12 unless you replace everything. GC
Old 06-17-2018   #3
jss06c6
134 operates at a higher pressure and expansion is the cooling process, so I get the need for proper pressure switches, but can't make the case for a different condenser unless the R-12 version is working at it's pressure limit, or, the R-134 unit has significantly more heat exchange surface area. I would be more inclined to think the expansion valve is different for R-134 to get proper cooling phase change (liquid to gas). Interested in thoughts.
I'm not wanting to chase R-12 at the price I have to pay for it. I'd rather modernize the system while I've got it down.
Sent from my QTAIR7 using ZR-1 Net Registry mobile app
Old 06-17-2018   #4
High pressure switch for 134a opens (and open is fan run position) at 240 psi or close to it - high pressure switch for R-12 will not work correctly. Also, high pressure switch for 134a is almost none existent.
Old 06-17-2018   #5
jss06c6
Thanks for the detail. I certainly understand the higher pressures in 134A. When you say "high pressure switch for 134A is almost non-existent", what does this imply? Do you mean they aren't available?
Old 06-17-2018   #6
I believe the stock cycling switch has a screw adjustment between the prongs.. turnis 1/4 turn CCW for r134a
Old 06-17-2018   #7
You can find them, just need to know where to look
Old 06-17-2018   #8
jss06c6
Thanks Jeff!
Steve
Old 06-18-2018   #9
rossgn49u
Curious as to why switching from R-12 to R134?
rossgn49u is offline   Reply With Quote
Old 06-18-2018   #10
jss06c6
Availability and cost of 134a vs 12. Current system has a slow leak. PITA finding and buying R-12. Just not worth the headaches to me. If I were buying another pre-94 Corvette and the prior owner had done a proper job of converting to 134a, I would pay extra for the upgrade.
