![]() Join Date: Aug 2015
Gents,
About to swap over to R-134. I've got the compressor and accumulator. To be clinically correct, I'll need to swap out the high pressure line to R-134 configuration. Anyone with one in good condition to sell, please send me a PM, otherwise I'll TIG in a new high pressure port. What about the high and low pressure switches. Are the R-12 switches compatible with R-134 and the higher pressures? If they need to be replaced, are they available? Thanks! Steve Sent from my XT1585 using ZR-1 Net Registry mobile app |
#2 | |
134 operates at a higher pressure and expansion is the cooling process, so I get the need for proper pressure switches, but can't make the case for a different condenser unless the R-12 version is working at it's pressure limit, or, the R-134 unit has significantly more heat exchange surface area. I would be more inclined to think the expansion valve is different for R-134 to get proper cooling phase change (liquid to gas). Interested in thoughts.
I'm not wanting to chase R-12 at the price I have to pay for it. I'd rather modernize the system while I've got it down. Sent from my QTAIR7 using ZR-1 Net Registry mobile app |
![]() Join Date: Aug 2006
High pressure switch for 134a opens (and open is fan run position) at 240 psi or close to it - high pressure switch for R-12 will not work correctly. Also, high pressure switch for 134a is almost none existent.
#5 | |
![]() Join Date: Jul 2007
I believe the stock cycling switch has a screw adjustment between the prongs.. turnis 1/4 turn CCW for r134a
1990 Corvette ZR-1 #1051 Watson Headers (2" Primary) - Flowmaster Cats - Borla Catback Late Model IH - Plenum Coilovers - 4.10s Shelby Series 1 - Wilwood Brakes Custom Interior NCM Lifetime Member #978 Last edited by -=Jeff=-; 06-17-2018 at 11:45 PM. |
You can find them, just need to know where to look
#8 | |
Steve Sent from my QTAIR7 using ZR-1 Net Registry mobile app |
Curious as to why switching from R-12 to R134?
#10 |
Availability and cost of 134a vs 12. Current system has a slow leak. PITA finding and buying R-12. Just not worth the headaches to me. If I were buying another pre-94 Corvette and the prior owner had done a proper job of converting to 134a, I would pay extra for the upgrade.
