#21 |
![]() Join Date: Dec 2014
1989 Challenger Super-Vee
24ft fully rigged, minus power & drive (just begging for that LT5 combo!) Currently available. CA1A7129-077A-4F19-8804-87484963F547-1.jpg Sent from my SM-N920V using Tapatalk |
#22 |
![]() Join Date: Nov 2011
I remember hearing a story that they had to design a special prop for the LT5 because of the high RPM
#23 | |
![]() Join Date: May 2010
Did you see the Dunn heads the same seller has for sale? https://rover.ebay.com/rover/0/0/0?m...2F282973265403 Sent from my iPhone using ZR-1 Net Registry
#24 | |
Did you see the photos of the other engine and misc parts in the first listing the seller says will be posted later? H ![]() |
#25 | |
I thought it was cool and pretty wild looking myself. I saw that and it prompted me to see what else he had out of curiosity. Sounds like a nice stash of some good stuff. Thanks for sharing the link. Sent from my iPhone using ZR-1 Net Registry
#26 |
![]() Join Date: Dec 2003
No photos of cam covers to see if numbers match cyl heads. May be worthless for anything more than souvenirs. Heads are bare with only valve guides. IF the heads are even serviceable, they will need;
16 Intake Valves 16 Exhaust Valves 32 Valve Spring Seats 32 Valve Spring Retainer/Caps 32 Sets Valve Spring Keepers 32 Valve Stem Seals 1 RH Dunn Tensioner Sleeve 1 RH Dunn Tensioner Cover Guides Reamed Seats cut Valves/Seats Ground/Lapped It's expensive to outfit heads for a 32 valve engine.
#27 | |
Buy it Jerry; you have all the parts.....lol. Sent from my iPhone using ZR-1 Net Registry
