Go Back   ZR-1 Net Registry Forums > C4 ZR-1 > Detailing, Cleaning, and Waxing
Old 05-08-2018   #1
Eclay3
Eclay3's Avatar
Default What would be the best way to clean oxidization/corrosion from wheel?
My wife and I just inherited our 1990 Z and we have been cleaning it a bit an when cleaning the wheels I noticed the oxidization/corrosion. I tried to clean them with simple green and 0000 wool and mothers mag polish but it won’t come off.
Eclay3 is offline   Reply With Quote
Old 05-08-2018   #2
S.hafsmo
S.hafsmo's Avatar
Default Re: What would be the best way to clean oxidization/corrosion from wheel?
Unfortunately, I think the only way to get a decent result is to have a wheel shop re-machine the wheel. Paint or polish would remove the original machined finish.
Wheels Techniques in CA qouted $209 /each wheel.
I've had this done to a set of '93 sawblades, and they turned out great.
- '90 ZR-1
Old 05-08-2018   #3
KILLSHOTS
Yeah, they were clear-coated from the factory, so steel wool will only damage that further. Your only options are to remove the clear completely and polish them, or take them to an expert for refinishing.
Old 05-09-2018   #4
Eclay3
Eclay3's Avatar
Thank y’all for the replies. Now I know for future projects not to use wool.
Would anyone have a recommendation on a good shop in the Houston TX area?
Old 05-09-2018   #5
S.hafsmo
S.hafsmo's Avatar
Might be possible to clean them up by removing the clear coat, and use some mild abrasive along the "grain" of the machined surface before re-coating with clear.
- '90 ZR-1
