04-11-2018 | #21 |
Re: Engine Pull/Install with headers
Hans,
Did the cams for the first time last year using the updated instructions from Marc posted on his business site. Takes time but once one cam done, others follow quickly. Tony - Tnova |
04-11-2018 | #22 |
What would be helpful is if there was a video of this process. Haven’t found one yet.
H
90'ZR-1 #1461 Red/Black Ported Intake, Degreed Cams, OBX Headers & Exhaust, Fidanza FW, Secondary Delete, Custom tune, C6 GS Wheels. Sold 08 C6 Z51 Crystal Red Metallic Sold Vararam Intake, Tune, Sold 05 C6 Z51 Red/Black Sold 90'ZR-1 #1723 Black/Gray Sold but not forgotten 91' Z51 L98 White Vert. My First, you always remember your first. Sold. |
04-11-2018 | #23 |
If you do decide to time the cams, by any method, you must replace the cam sprocket bolts. Quite a few engines have had major damage due to broken, OEM bolts which are torque to yield, one use only.
04-11-2018 | #24 | |
H
04-13-2018 | #25 |
Yes, what Jerry said. I used the old bolts while timing the cams. Once the timing was set, installed the new bolts.
