Old 04-09-2018   #11
tf95ZR1
tf95ZR1's Avatar
Default Re: Flying 1/4 mile racing
That was absolutely AWESOME, Glen!
Thank you for the videos.
Your car sounded great and was very stable.
This is an event perfect for our cars:
Torque/HP and aerodynamic.
I have done this on smooth (sometimes)
and wide runways. This was NARROW!
No doubt, you have kahunas! As said
before, good, new tires are safety #1.
And a trick for next time: Shift into 6th
when you are done to slow down. Then
brake and downshift.
The Mojave Magnum (1.5 miles) is this
coming weekend. I'm missing it for
various reasons. Your videos make that
even more sad. :-(
Ted
Old 04-09-2018   #12
PhillipsLT5
PhillipsLT5's Avatar
3.45 gears?
Old 04-10-2018   #13
At least there weren't any trees or fence post you would hit if you went off road
Old 04-10-2018   #14
gtcollins@maxnet.co.nz
gtcollins@maxnet.co.nz's Avatar
Originally Posted by efnfast View Post
Holy crap, that road ain't wide enough for that kind of speed.
Hi we have to do the race on b grade roads that one is 23ft wide would be a lot nicer if the road was wide
Sent from my SM-G930F using Tapatalk
gtcollins@maxnet.co.nz is offline   Reply With Quote
Old 04-10-2018   #15
I am impressed [emoji106] [emoji106]
The second video was in 5th?.......How fast?
Great video from inside car [emoji106]
Hi all I went racing again last weekend this time I did a flying 1/4 mile we had 1.5 miles run up 1/4 mile timed section 1.5 miles run down on the timed section I got to 176 mph both ways then I kept going after the timed section and got up to 184 mph on my GPS before I had to slow down here's a couple of videos of the race both videos are of the same race we got 7 runs all together Yes 5th gear I didn't try 6th as I think it would be slower
Old 04-10-2018   #16
Holy crap is right!!!! Luv the shift light location. Hope those tires are new otherwise it’s lights out with those trees on either side if one blows. Looks like great fun.
H
Hi yes the tires brand new a friend even transported the wheels and tires to the event and the front still have the little dots on them the shift light I made up with leds and the position idea came from Mark Horner I'm us a auto meter controller to drive the light
Old 04-10-2018   #17
even more sad. :-(
Ted
Hi Ted this was my first attempt at this sort of event if you have any suggestions on how to get more speed that would be great I was running 40psi in my tires I also made defuser for the back of the car you can see the exhaust sticking thought as well
Old 04-10-2018   #18
Originally Posted by PhillipsLT5 View Post
3.45 gears?
Yes standard diff gears 3.45 I think going to 3.07 might help get a little more speed
Old 04-10-2018   #19
tf95ZR1
tf95ZR1's Avatar
Only if you have an engine big enough to pull your car at high speeds with these gears. There is a "sweet spot"
matching your engine and gears to achieve the result you want, in this case top speed. Even transmission
gear ratios can be changed. Obviously, depends on how deep you want to get into this (& $$).
That diffuser is AWESOME! In place of the spare?
This is the ultimate, I believe: Dave (Daves Obsession), from Texas has a ZR-1 Bonneville car he talks about:
https://www.corvetteforum.com/forums...t-up-date.html
Lots you can learn from this.
You can surely get hooked on this kind of racing.
Old 04-10-2018   #20
HAWAIIZR-1's Avatar
Awesome!!! Thanks for sharing.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
