Old 04-09-2018   #21
Ccmano
Default Re: Z06 Cats
I decided on Magnaflows as well. Have them sitting here waiting till the engine swap is done. Also decided on the secondary delete. Pulled the old engine yesterday. Moving right along with the project.
H
Old 04-09-2018   #22
since you have the motors out.. could you get me a couple pictures of that plate that comes loose. Lower front passenger side..
I still have an oil leak I would like to track down, I believe it is coming from the front or the front right of the motor
Old 04-09-2018   #23
Ccmano
Yeah that’s fun to get to with the motor in the car. Remove the K members and nut from the engine mounts. Raise the engine with a jack an inch or more. You can just get in there to tighten the cover bolts. Good time check the engine mounts as well.
Here’s some pix.
H
