Old 12-17-2017   #21
Default Re: Larger Intake Valve Cylinder Head Work
Love those velocity stacks & 3" primary tubes. Are you building a new GT car? Individual cylinder throttle body w/injector? Just kidding of course, but with you there's no half-stepping!
Awesome work Phil!
Old 12-17-2017   #22
mgbrv8
Great work Phil
Dave
Old 12-18-2017   #23
Jagdpanzer
Jagdpanzer's Avatar
Awesome work Phil!
Jerry,
Glad you like my home made velocity stacks.
Found them at Home Depot in the the plumbing department PVC pipe fitting section for $1.79. A little time on the lathe and Voila! Shop vac floor attachment tube was the donner for the primary exhaust extension pipe. Though it appears to be larger ID measures 2”
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 12-20-2017   #24
Jagdpanzer
Jagdpanzer's Avatar
Ran the flow test this morning
Here is the head mounted up on the SF-600 flow bench with test engineer Justin getting ready to hit the switch:
Flowing intake ports:
Flowing the exhaust ports:
And the results:
Happy to report the achieved flow numbers were inline with expectations so the larger intake valves and additional porting work paid off. Was especially pleased with the flows at lower intake valve lift points. The shop that performed the test had never seen a LT5 head before and was very impressed. Said it was right up there with the best SBC LS aftermarket heads they've tested on a 4.125" cylinder bore.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 12-20-2017   #25
QB93Z
QB93Z's Avatar
Well Done Phil. Thanks for sharing this development with us.
If it isn't fun, you aren't doing it right!
1990 Black ZR-1 - sold
1993 Quasar Blue ZR-1
1994 Competition Yellow ZR-1
1995 Dark Purple ZR-1
Maryland State Coordinator
Old 12-20-2017   #26
5ABI VT
That is awesome !! Can’t say I’m all that familiar with LT5 flow numbers but have seen a few that aren’t that high that’s for sure ! Any before numbers or any stock numbers for reference ? Would be cool to graph it just for comparison purposes
Old 12-20-2017   #27
Pete
Pete's Avatar
Great Job Phil.
Numbers look almost identical to the ones i have done 15 years ago with stock valves.
Just for comparison.
Intake
.300 275
.400 328
.450 337
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 12-20-2017   #28
Jagdpanzer
Jagdpanzer's Avatar
Thanks Pete
You are the LT5 porting expert, I am just a mere novice.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 12-20-2017   #29
Roadster
Roadster's Avatar
Congrats Phil.....glad you reached your goal.....
1974 LS4 454 Vert
1974 L-82 355 Vert.
